SOLD!
Factory five Cobra with IRS option. Non Donor build P1020108.jpgP1020109.jpgP1020122.jpgP1020125.jpg
Car has approx 9500 miles, always garaged
Cost to build - approx $45,000 (Have spreadsheet with details)
Selling price - $40,000, Price drop to $36,000
New Engine,Transmission & clutch 01/25/2016) Spec sheet available
393 cu short block (450hp)- steel crank, forged steel rods & pistons ARP fasteners
Balanced & blueprinted (28oz) build sheets included
New Ford Racing Z304 aluminum heads M-6049-Z304DA with ARP studs
T&D shaft rocker arm system
Wiend 'Stealth' manifold
Lokar Throttle bracket kit
New Holley 750cfm "double pumper" carburetor
Custom tune by Oakes Racing - 450hp+
Big Block Cobra 427 aluminum valve covers
Crane "Fireball" Electronic ignition with rev limiter
New MSD Pro-Billet distributor
New Ceramic coated tubuler headers
Polished Stainless Side Pipes
Accessories drive kit -Aluminum bracket & pulleys front engine
LevyRacing Super Alloy T5 Gear Box
Steeda Triax Shifter, Trans Mount & Bushing`
Steeda Adjustible Clutch Cable, Quadrant & Firewall Kit
Broward Powertrain custom driveshaft with safety loop
8.8 IRS differential
Perma Cool fuel/water seperator bracket & filter
Polished Aluminum Catch Can (1 quart)
aluminum high flow radiator
Complete Mustang Cobra Brake Kit (new) - Front (dual piston) & Rear
Carbotech High Performance Brake Pads
Staniless Steel Brake Lines throughout
CNC dual brake master cylinder, with cockpit brake bias adjuster
Adjustible Vintage sway bars front & rear
Tubular Front upper & Lower control arms
Coil over shocks
Cockpit:
'Rolled' cockpit edges
Quick detachable steering wheel hub (good security feature)
Choice of leather covered or traditional wood steering wheel
Windwings kit
Custom leather dash with glove box
Left & Right Leather door panels
Leather covered console
adjustible footwell vents
WSH Carbon Fiber Seat Heaters
'Dropped' and extended passenger footbox
Autometer 'Vintage Cobra' guages with reverse speedometer (includes Oil Temp guage)
Low oil pressure warning light
Battery Cut-Off switch
Upgraded "bear claw" door latches
NC painter - body work and paint
Custom black paint with 'ghost' grey racing stripes
hidden trunk hinges
Team III wheels
If interested, have questions, or want more pictures
Contact: [email protected]
