Thread: GTM Kit with C5 Corvette Donor Parts
    Tech Support, FFR
    Price: $29,990
    To purchase, call Factory Five at 508-291-3443.
    For anyone who has ever considered building a GTM kit, Factory Five has an exclusive package just for you. Due to a canceled project by Factory Five, we are able to offer you this GTM kit with a Donor Parts Package! This GTM kit contains the following options from Factory Five:
    00-04 Exhaust Option
    G50 Style Transaxle Adaptor
    GTM F14 Style Wheels
    Carbon Fiber Splitter
    Carbon Fiber Rocker Extensions
    GTM Roof Scoop
    GTM Fender Louvers
    GTM Logo Floor Mats
    Parts Included with the Donor Takeoff Package:
    GTM DONOR PARTS LIST (1997-2004 C-5 CORVETTE)
    1 pair LH/RH Front lower control arms (rubber bushings installed and ball-joints pressed in)
    1 pair LH/RH Front upper control arms (rubber bushings installed)
    1 pair LH/RH Knuckles (upper ball-joints pressed in)
    2 each Front bearing/hub assembly
    1 pair LH/RH Hub backing plates for wheel speed sensor wiring attachment
    2 each Locknuts for lower ball joints (M14 x 2mm)
    2 each Locknuts for upper ball-joints (M12 x 1.75mm)
    6 each Torx bolts (T55) for bearing/hub assembly to knuckles (M12 x 1.75mm x 55mm)
    8 each Bolts for upper control arm to chassis (M10 x 1.5mm x 35mm)
    8 each Washers for upper control arm to chassis (10mm)
    4 each Cam bolts for lower control arms to chassis (M14 x 2mm x 110mm)
    4 each Locknut for lower control arm bolts (M14 x 2mm)
    4 each Cam washers for lower control arm bolts
    4 each Bolts for lower shock mount (M8 x 1.25mm x 45mm)
    4 each Locknuts for lower shock mount (M8 x 1.25mm)
    1 pair LH/RH Front rotors
    1 pair LH/RH Front calipers with sliders and hardware to attach sliders to calipers
    4 each Bolts for front calipers to knuckles (M14 x 2mm x 47mm)
    4 each Washers for calipers to knuckles (5/8” ID, 1 1/8” OD)
    2 each Flexible brake lines with mounting brackets (front, slightly shorter than the rears)
    2 each Banjo bolts with 4 crush washers for brake line attachment to calipers (M10 x 1.0mm)
    2 pair Front brake pads
    FRONT SUSPENSION
    10 each Lug-nuts for front suspension (M12 x 1.5mm)
    1 pair LH/RH Rear lower control arms (rubber bushings installed and ball-joints pressed in)
    1 pair LH/RH Rear upper control arms (rubber bushings installed)
    2 each Rear bearing/hub assembly
    2 each Cam bolts for lower control arms to chassis, forward most mount (M14 x 2mm x 110mm)
    2 each Locknut for lower control arm bolts, forward most mount (M14 x 2mm)
    2 each Cam washers for lower control arm bolts, forward most mount
    1 pair LH/RH Rear rotors
    1 pair Rear calipers with sliders and hardware to attach sliders to calipers
    4 each Bolts for rear calipers to knuckles (M14 x 2mm x 47mm)
    4 each Washers for rear calipers to knuckles (5/8” ID, 1 1/8” OD)
    2 each Flexible brake lines with mounting brackets (rear, slightly longer than the fronts)
    2 pair Rear brake pads
    10 each Lug-nuts for rear suspension (M12 x 1.5mm)
    2 each Outer CV-joints
    2 each Locknuts for outer CV-joints (M27 x 2mm)
    2 each Rear toe link
    2 each Locknuts for rear toe link to chassis (M16 x 2mm)
    2 each Rear outer tie rods with jam nuts (M14 x 1.5mm)
    REAR SUSPENSION
    2 each Locknuts for tie rod ball-joints (M12 x 1.75)
    1 pair LH/RH E-brake backing plates (includes brake shoes and cylinders)
    1 pair LH/RH e-brake cable to knuckle brackets
    4 each Bolts for e-brake cable to knuckle brackets (M10 x 1.5mm x 70mm)
    2 each E-brake cables
    1 each E-brake handle (includes attached front cable with equalizer bar, black hand grip and boot)
    E-BRAKE
    1 each E-brake cable connection bracket (connects front cable to both rear cables)
    1 each LH Fuel tank with pumps and sending units
    1 each RH Fuel tank with pumps and sending units
    1 each Fuel tank connector tube (only necessary if tanks came from 2003-2004 donor)
    1 each Fuel filter
    FUEL
    1 set Hard lines connecting filter to tank (3 total)
    1 each Fan shroud
    2 each Fans with attached motors and screws to attach to shroud
    1 each Radiator
    1 each LH/RH Radiator lower rubber isolators
    1 each Coolant overflow tank
    COOLING
    1 each Cap for coolant overflow tank
    1 each OBD2 PCM computer
    1 each Computer 2 piece mounting bracket
    1 each TAC module (for fly by wire throttle)
    1 each Throttle pedal (fly by wire)
    1 each Fly by wire harness (connects throttle pedal to TAC module)
    2 each Short 4 wire oxygen sensors
    2 each Long 4 wire oxygen sensors
    1 each Vehicle speed sensor (VSS) with mounting bracket
    1 each Engine Harness
    1 each Brown plug that connects to the under-hood fuse box with about 12 inches of all wires extending out
    of it (for connection to the fuel pump, and ignition switch)
    1 each White plug that connects to the under-hood fuse box with about 12 inches of all wires extending out
    of it (for connection to cooling fans and air pump, fuel level sender, and vehicle speed sensor VSS)
    1 each OBD2 Engine scan plug with about 12 inches of all wires extending out of it
    1 each Wiring plugs for fans, fuel tanks, brake light switch, wiper motor to steering column
    1 each Under-hood fuse box
    1 each Brake light switch with plastic holder
    ELECTRICAL
    1 each Ignition switch
    1 each Ignition cylinder, lock cylinder(s) and 2 key set
    1 pair LH/RH Exterior door handles with gaskets
    1 pair LH/RH Exterior rear view mirrors w/mounting nuts
    2 each License plate lights with bulbs, mounting screws (leave about 12 inches wire from each bulb socket)
    1 each Horns with mounting bracket (high note and low note)
    1 pair LH/RH hood latches
    1 each Hood release handle and 2 attached cables
    2 each Hood strikers
    1 pair LH/RH hood hinges
    1 each Wiper motor with rotating assembly and 3 mounting screws
    1 pair LH/RH Power window mechanisms
    1 pair LH/RH Seat belts w/upper bolt plastic covers
    2 each Seat belt receptacles
    1 each Steering column (w/stalks, 2 piece cover, steering wheel nut M14 x 1.5mm)(non-telescoping best)
    All Parts are good used components that were professionally removed from a Corvette Salvage yard. You will need the following components to complete this build:
    Complete LS-1 or LS-6 C5 Corvette Engine with Wiring Harness and Computer
    Complete Porsche G50 Transaxle from 90-98 with CV’s, starter, and clutch
    Tires
    Battery
    Paint Job
    This Kit Retails for $38,801.00 including the donor parts, but it is available for $29,999.00. That’s over $8,500.00 in savings, which makes this the most discounted GTM kit in Factory Five History! Only 1 of these kits are available, so act fast. Terms and Conditions are listed below:
    Cannot be combined with any other offer.
    Sale does not include shipping & handling, or crate fees.
    Orders must accept the next available completion date.
    Some restrictions may apply for international orders.
    $1,000 deposit is required at time of order and is non-refundable.
    Odonus - gtm - Exclusive Package
    I am keen to persue the offer and would like to place a deposit for the vehicle
    Please note that I reside in Australia and this would be a beneficial build considering C5 corvette parts need to be sourced from USA
    Please make contact via PM or email ([email protected]) so that I can make deposit and other arrangements
    cheers
    Odonus
    Quote Originally Posted by Dan Golub View Post
    Price: $29,990
    GTM Roof Scoop
    GTM Fender Louvers
    GTM Logo Floor Mats
    FRONT SUSPENSION
    REAR SUSPENSION
    E-BRAKE
    1 each Fuel filter
    FUEL
    1 each Fan shroud
    1 each Radiator
    COOLING
    ELECTRICAL
    Tires
    Battery
    Paint Job
    PM sent
    Mark Dougherty's Avatar
    Hershey PA
    odonus
    call the factory
    1-508-291-3443
    ask for Dan Golub
    He will take care of you
    The traveling Builder
    717-773-5624
    Quote Originally Posted by Mark Dougherty View Post
    odonus
    call the factory
    1-508-291-3443
    ask for Dan Golub
    Thanks - have made contact with Courtnie Provencher via email
    Time difference is a pain between Australia and USA - but will try again later tonight my time
    cheers
    O
