Thread: Dash design
    Dash design
    I finally cut out the face of the dash for easy access to all the work that needs done back there. I will make L&R plates from 1/8" AL to mount the gauges in.
    I'm looking for suggestions for gauges that will cluster behind the wheel because I don't care for them spread all across the cockpit. I also want a speedo that
    is marked to 180 or more and a lot of them seem to stop at 140 now. Help me spend some money and find just the right cluster for mine. Here's the blank slate.
    Dale B Hemi33
    Senior Member maczter's Avatar
    Feb 2013
    Xenia, OH
    Sounds like Speedhut may be your answer. They do custom electronic gauges and may be shallow enough to mount behind the steering wheel without interfering with the brake valves.
    http://www.speedhut.com/gauges/Speed...ortby=prodname
    FFR HR #530
    Race car theme, Tim Whitaker roll bar, Autometer Autolite Gauges, Satin Black, SBC 383/700R4, 8.8 rear with Cobra Brakes, 3.29 gear, Boyd Tank, QA1 springs and shocks,
    My build blog: http://jacks33hotrod.blogspot.com/
    Quote Originally Posted by maczter View Post
    Sounds like Speedhut may be your answer. They do custom electronic gauges and may be shallow enough to mount behind the steering wheel without interfering with the brake valves. http://www.speedhut.com/gauges/Speed...ortby=prodname
    Mac
    Thanks for the link, that looks like it might be the best set-up for mine.
    I like the white face gauges because they are easier to read for an old fart. One of the other things I have been considering is to space out the dash front IF I need the extra depth for gauges.
    Dale
    I installed the vintage air unit behind the dash today. Working through the big hole in the dash was a breeze, I can't imagine trying to do it any other way.
    I shortened the top bracket, then bent the last inch of it over 90* to lay on top of the top firewall tube. The one on the blower housing got bent 90* as well
    to rest over that angled tube. Both brackets got new holes punched in them with a Whitney punch so the new holes were properly centered on each tube.
    I leveled the unit then marked and drilled the firewall tubes and installed 1/4 20 rivnuts for the two housing brackets. Then I cut off a couple bolt heads and
    installed the studs in those rivnuts and bottomed them out against the back of the tubes leaving 1/2" projection. Hanging the unit on those two studs was easy
    and I will double nut them when I know it's there to stay. I did leave the studs a bit long in case something else needs a mounting point under there later. They
    might even make good grounding points if I need them for that as well. I didn't find a good method for bracing the bottom of the unit though so any suggestions
    for that are appreciated, it seems like the bottom could swing in and out maybe even thumping the firewall at times.
    I had to set mine more to the center so I can get to the bolts for the roll-cage later but that also lets me have a smoother path for the heat and AC hoses.
    Dale
    Gauge mfr.s
    Dale here are some Gauge Mfr.s
    These should help you out.
    Aurora Instruments
    http://www.auroragauges.com/
    Auto Meter
    http://www.autometer.com/
    Auto Meter Custom Shop
    http://www.ampcustomshop.com/
    Classic Instruments
    http://www.classicinstruments.com/
    Dakota Digital
    http://www.dakotadigital.com/
    Dolphin Gauges
    http://www.dolphingauges.com/
    GlowShift
    http://www.glowshiftdirect.com/
    NVU (New Vintage USA)
    http://newvintageusallc.mybigcommerce.com/
    Speedhut
    Stewart Warner
    http://www.stewartwarner.com/
    VDO
    http://www.vdo-gauges.com/
    Veethree Instruments
    http://www.v3instruments.com/
    Enjoy!
    33 Hot Rod #664 BrentM's Avatar
    May 2013
    I used the FFR Autometer gauges and I have a hydraulic clutch ... It all fits, pretty tight but it works
    Here are a few pics....
  7. Likes theidlemind liked this post
    Nov 2016
    Mi.
    Looks great, I am planning to do similar layout, where did you get the consul ?
    Simi Valley, CA
    If you mean the dashboard, talk to Tim Whittaker: http://thefactoryfiveforum.com/showt...light=Kootenai. I just ordered one from him. Keith
  10. #9
    I've use clusters from Dakota Digital in other cars and really liked their products.
    http://www.dakotadigital.com/index.c...=cat/cat69.htm
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
