0
0
Water temperature gauge
I have the fan thermo switch in the water neck and everything works great. I would like to know the water temp as well while driving. My fan comes on at 185 and goes off at 150. If the water temp goes up to 210, I need to know. Here in west Texas, 105* with the a/c on, I would not hear the fan while driving down the highway. With only one place to use on the neck and it's filled with the thermo switch, has anyone tried to use a temp sender somewhere else and used a water temp gauge? Any suggestions other than drilling and tapping in the intake will be appreciated. My engine is a 347 Ford. Thanks. John
Found a bung hidden underneath my coil!
- You may not post replies
- You may not edit your posts
Forum Rules
