0
0
2002 WRX Donor parts - 80% complete
I recently picked up and disassembled a donor for my upcoming 818 build, i found a great deal on another WRX last week and picked it up as well. I plan on rallycrossing the new WRX until it dies then tearing it down for a second 818 kit.
Just gauging interest in the donor parts currently sitting in my garage. I would prefer to sell them as a package deal, located in Columbus, Ohio.
Legend:
n = Need
c = Have
z = Have but pending local sale
A lot of the stuff still needed I had planned on going aftermarket (control arms, seats, trailing arms, etc)
Front Drivers Lower Control Arm n
Lower Rear Trailing Arms n
Intercooler n
Steering Wheel - Airbag n
Airbox n
Wheels and Tires n
Seats n
Shift Knob and Boot n
Hazard flasher switch n
Radiator n
Fans with mounting bracket n
Upper and Lower Radiator hoses n
Fill/Burp Tank n
Overflow Tank n
Battery n
Side Mirrors n
Front CV shafts n
Turbo Inlet tube n
Exterior Fuse Box n
Rear Swaybar with chassis mount bushings and brackets n
Shifter knob n
Shifter boot n
Struts/Springs n
Down-pipe with cat (if turbo) n
Engine and Transmission mounts x
Front Spindles x
Front brakes (complete) x
Front Flexible Brake lines x
Front CV joints complete with axle nuts x
Strut to Spindle mounting hardware x
Steering rack with outer tie rods x
Steering shaft complete x
Steering Column - lower bezel x
Rear Spindles x
Rear Brakes Complete x
Rear Flexible brake lines x
Emergency Brake Cables x
Lower forward Control Arms x
Rear Toe Links x
Rear Outer CV joint x
Shift Linkage mount to Transmission x
Starter x
Exhaust Exhaust manifold and Y pipe x
Up-pipe (if turbo) x
Oxygen sensors x
Instrument Cluster x
Emergency Brake Handle x
Rear seat belts with receptacles x
Interior Door Latches x
Rear View Mirror x
Complete pedal assembly x
Throttle pedal x
Brake Master Cylinder x
Clutch Master Cylinder x
E-brake cable mount bracket x
Fuel Pump with Sock x
Complete Vehicle Wiring Harness x
Battery Cables x
Rear Door Hinges x
Rear Door latches with catch x
Hood Hinges x
Horn x
Charcoal Canister x
Optional Windshield Wiper Assembly x
Brake Booster x
Brake light Switch x
Complete Engine with Alternator z
Transmission with Flywheel and Clutch z
If you need an OEM intercooler I have one. Also have a bigger aftermarket one.
- You may not post replies
- You may not edit your posts
Forum Rules
