Results 1 to 14 of 14
Thread: NASA rules
    Carrollton, Ga.
    NASA rules
    Just a quick question for those familiar with the weight:hp classes and modification factors in ST1/ST2/ST3; I can't find the answer to my question in the NASA rules. (It may be so straightforward that no explanation should be necessary!)
    These classes fall into the 5.50:1, 8:1 and 9:1 weight to power groups. If modifications increase or decrease these ratios to give a competitor his final "score," what is the implication of that? I can't find ballast penalties to equalize, as in the Challenge series. Is it just that one's final car prep leaves him with a modified ratio, and that, if he is beneath the breakpoint between classes, he must go to the next class and is otherwise OK?
    Thanks for any help.
    Bill
    Maricopa AZ
    ST2 is a really good class for the car. You can also do ST3 but I think it would be more competitive in ST2.
    Wareham
    Bill,
    You add up all of your modification factors like tires, weight range, aero mods, etc, and it will give you the power to weight that your car needs to be over to be in each class. If you are just over powered or underweight you get bumped up into the next class, however adding ballast, intake restrictors, or narrower tires can get you back down to just under the maximum in a lot of cases. If you are going challenge legal then my personal opinion is run 245 hoosier a7s and ballast up to the next weight break to run ST2, however you can also trim down to ST3 where there are harsher aero penalties to have to compete against.
    Jim Schenck
    Factory Five Racing
    Nashua, NH
    Bill,
    Here is the math I use based on 2016 ST2 rules. you start at 8.0:1, then add/subtract deductions.
    min weight of 2600lb = -.1 weight factor
    250-275 DOT = +.3
    aero - vehicle specific = -.2 (FFR cobra with aero)
    (raw weight/hp = 8:1)
    So, I can have 325HP (2600/8)
    245 and smaller = +.7
    (raw weight/hp = 7.6:1)
    So, I can have 342HP (2600/7.6)
    http://johngeorgeracing.com
    Apex, NC
    Similar I am going for ST3:
    No Extra Aero
    (raw weight/hp = 8.4:1)
    That gives me 309 WHP.
    With the upgrades I am at 321 WHP, so just a ~3% throttle stop should do the trick, or tune the ECU.
    So very little change from Challenge rules gets me in ST3.
    2012 NASA-SE FFR Champion
    2011 NASA-SE FFR Champion
    Race page - http://www.mh-motorsports.com/race.shtml
    Team Facebook page - http://www.facebook.com/pages/MH-Mot...s/264814350042
    Maricopa AZ
    Take 4 degrees of timing out will do the same thing.
    Apex, NC
    What would be perfect would be a smart tune that cut timing out at 4500 RPM in forth gear only.
    Want a challenge?
    BTW, this is one of your builds.
    Maricopa AZ
    Which one would that be?
    Apex, NC
    Spencer Sharp's old car. The red and silver one
    It's been a great car, and I somehow even managed to even win a couple of regional championships with it
    Carrollton, Ga.
    Thanks, guys; your comments clarify things a great deal. Now to build & see how it turns out! Probably be ordering car tomorrow; am building engine and have TKO, clutch, etc ready to go.
    Appreciate the response.
    Bill
    Maricopa AZ
    Nice Howard, how do you like all the intrusion protection we put in?
    Maricopa AZ
    Bill, Call me about set up and brakes. There is a ton we have figured out in all the years of racing these things.
    Apex, NC
    It's all been great. The car has been dead reliable and performed as expected. I just wish the driver was as good.
    Carrollton, Ga.
    Will do, Gordon; am ordering car tomorrow; I'll call you in AM.
    Bill
