20160505_155520.jpg Does anyone know what these parts are that come with the complete kit?
LH side = cooling fan mounts for donor fan. BTW, nice mild steel stock. I typically use them up fabricating other parts.
RF side = part of hood pin assembly.
Neither will be used with your complete kit if you received an FF radiator, cooling fan, and hood hinges. Those probably aren't the only parts you won't be using.
Thanks. I was wondering from day 1 and then had them powder coated just in case they were necessary.
