Results 1 to 3 of 3
Thread: Hydraulic brake light switch
    Nov 2015
    Elverta, CA
    Lightbulb Hydraulic brake light switch
    With all the problems I have had getting these brakes to work properly, I learned it is impossible to adjust the cheap plastic swich supplied with the pedal assy. Junk is best description for this setup! Every minor change to pedal height neccisitates an adjustment. I'd love to see the ffr guys do this.
    I finally gave up, ripped out the switch and replaced it with a pressure switch from summit racing. I tee'd it into the rear master cylinder so I could use the existing wires. If I was starting from scratch, I would probably put the tee down on the frame at a junction in the line.
    Here is a picture of the completed switch:20161009_141015.jpg I hope if clears the speedo, but if not I will change orientation somehow.
    The parts I used are:
    Edelmann "trailer brake tee" #12733 from Oreilly auto parts $8.75
    Edelmann 3/16 inv flare - 1/8 npt fitting #361320 shopeddies.com $14.00
    1/8 npt brass coupler local hardware store $2.20
    Switch and harness summit racing.com sum-890002 $19.92
    Total $44.87
    Savings to me in labor, pain and suffering? Freakin' PRICELESS.
    I've used that switch in my GT40 and in my current roadster build. Works like a charm
    Nov 2015
    Elverta, CA
    Quote Originally Posted by 2FAST4U View Post
    you have no idea how good it makes me feel that someone else had this work for them. So much of this experience has been hit and miss that I never know what to expect. Thanks for the positive feedback.
