Hey there everyone,
So I realize that not everyone's budget can accommodate the Graziano gearbox options that are now available, so I thought it would be helpful to take a look at the Porsche 996 gearbox options.
The 996 gearbox has shown itself to be quite capable, and able to handle 650 hp and 550 ft-lbs or more without issue. There are a couple of different directions that you can go with.
The first would be the stock gearing ratios which are a bit short, but still quite drivable.
G96.01 stock ratios look like this
final drive 3.44
1st gear 3.818
2nd gear 2.2
3rd gear 1.516
4th gear 1.216
5th gear 1.024
6th gear 0.84
The second option would be to install a taller 3.0 ring and pinion which does add some cost but does also lengthen the gearbox ratios quite a bit as well.
Here is what you are looking at for your cost options.
$4600.00 New Factory Reman unit from Getrag (all new internals, only the case is reused.)
$2290.00 New OS Giken LSD (one of the very best on the market)
$1800.00 Adapter plate and flywheel
$200.00 Clutch release components
$220.00 New Slave Cylinder
$400.00 Gear reduction starter
$1250.00 Spec Stage II clutch kit
$795.00 Cable shift assy
$120.00 bolt kit
$11,675.00 Total plus shipping.
Now those of you who anticipate long drives at 80 mph, who do not want to be revving at 3000 rpm, there is a option to install a 3.0 ring and pinion into this gearbox. It is not cheap, but it will reduce your rpm's at 80 to 2500.
Cost on the 3.0 ring and pinion installed is $4000.00
I have actual gearing charts that I will be happy to email out to you if you would like them. They do not seem to load well here for some reason.
Happy to help, and please let me know what you think of this option.
Erik Johnson
The Race Line
(720) 899-6005 phone
