Results 1 to 2 of 2
Thread: 33 with SBC waterpump question
    I am building a 33 with a chevy 350. I had heard that I need to use a short neck waterpump. Is this correct? Please advise. Thanks. D. Sully
    The frontal clearance for a short water pump versus a long one is very small, about an inch.
    I cannot imagine that it would be a problem; however, I'm not building a 33 Hot Rod, but a SBC MK-4 instead.
    I can tell you that you have a better selection of after market accessories with the long water pump set up.
    C-2 and C-3 Corvettes all ran a short pump for a SBC application for what it is worth.
    Earlier C-4's ran a short pump that was reverse rotation. (1984-1991)
    Good Luck & Have A Great Build!
    Hopefully you can access this youtube link that shows the length difference.
    https://youtu.be/OdsWy6tgS5A
