Brent,
I shaved my door handles and use 50lb door solenoids to actuate the door release. Electrically, my door system is a bit complex - I'll explain below. I had a few goals with my shaved door popper system:
1. I wanted the clean look of shaved handles
2. I wanted a remote control to operate the door
3. I only wanted the door to open when my hand was on the door so it would not swing.
So, I incorporated an RF remote control unit;
that powers two (drivers/passengers) timer relays;
which provide 15 seconds of power to a capacitive sensor inside each door;
that when switched send power via a relay to the door solenoid and the door opens.
The capacitive sensors are mounted inside the door, near the trailing edge, in upper body line area where it begins to deepen and transition into the body side scoops. The solenoids and relays are mounted to the door frames, and the rf-receiver and timer relays are mounted under the dash.
So, as you walk up to the car you press the remote button. Just press it once - no need to hold it. You now have 15 seconds to place your hand on the door and wrap your fingers under the wide area of the body line. When the capacitive sensor senses your hand, the door solenoid actuates and the door opens. Since your hand is already on the door it is easy to open.
Sounds complex, but very easy to operate. With two huge benefits in my opinion:
1. You need the remote to open the car - you can't just "touch" the right spot and have the door open.
2. If you accidentally press the remote button while standing around or driving, the doors do not open - you need to touch the correct spot on the outside of the car.
Of course, if you wreck and have to be pulled from the car, they'll have to break the window to get you out
And yes, I do have a hidden mechanical override in case the electronics fail.
-Michael
