818 Junkie...
For Sale: Wilwood Dual Master Cylinder Kit
All new and unused.
$500 new, will sell for $250 OBO.
Newer Roadsters are already set up for This Wilwood petal. Master Cylinders are dependent on which Brakes you have. These cylinders are for PBR 2 piston fronts and Tbird Turbo Coupe rears.
260-3372 Master Cylinder, Aluminum, Natural, .625 in. Bore, 1.30 in. Stroke, Universal, Kit
260-3376 Master Cylinder, Aluminum, Natural, .875 in. Bore, 1.20 in Stroke, Universal, Kit
340-1757 These Wilwood balance bar assemblies are designed to maximize travel and adjustability, providing increased front-to-rear bias control. They feature a precision spherical bearing with a corrosion-resistant finish for durable, smooth performance. The threaded adjuster bar is manufactured from high-strength aircraft alloy and fitted with lightweight, maintenance-free clevises, and thrust washers to eliminate binding under extreme pivot angles.
340-4990 Wilwood's remote mount balance bar cable adjusters are used with dual master cylinder/single brake pedal assemblies to adjust the front-to-rear brake bias during the race--without leaving the seat! They feature a bright blue knob for adjustment, and a modifiable 5 ft. cable and housing for easy installation into tight areas. They include two labels for bias identification and fit all balance bars with 3/8 in. x 24 threads.
340-3950 Brake/Clutch Pedal, Aluminum, Black, Forward Mount, Universal
818R For Sale!
818R Sale Thread
PADI Master Scuba Diver Trainer, PADI TecRec Gas Blender Instructor, Operations Manager - DNS Diving, Grand Cayman
