Thanks Thanks:  12
Likes Likes:  114
Page 1 of 14 12311 ... LastLast
Results 1 to 40 of 554
Thread: Toms 33
    May 2016
    North of sacramento Ca.
    Toms 33
    Called FFR today and kit goes in truck tomorrow. Engine will be here tomorrow, and have drivetrain parts.
    I just hope that the last kit to go in truck is ready ?
    Congrats! have a ball building it.
    May 2016
  4. Likes River Mike liked this post
    Jan 2016
    Eye Candy!!!!!!!! Love the look of this setup. What tranny and clutch are you planning on using?
    May 2016
    Got the driveline parts from MDL. T56 magnum, with superior clutch kevlar/kevlar disk, tilton 6000 hyd. release.
    Quicktime bell and a lightened billet flywheel.
    May 2016
    Truck driver called ,should get to me on the 20th. yes, yes !!
    Congrats, have fun with the build.
    May 2016
    May 2016
    IMG_5880Toms 33 for net.JPG Working on inventory.
  11. #10
    May 2016
    Senior Member Motor_Freak's Avatar
    Feb 2014
    Los Angeles, CA
    Congratulation! Post more pictures.
  13. #12
    May 2016
    Just enough parts not on hand to put build on hold.
  14. #13
    May 2016
    Got gears changed from 3.55 to 3.73, dam tape glue is hard to get off, and built engine lift mounts.IMG_5899Toms 33 for net5.JPGIMG_5900Toms 33 for net5.JPGIMG_5902Toms 33 for net5.JPGIMG_5903Toms 33 for net5.JPGIMG_5904Toms 33 for net5.JPG
  15. Thanks Phil2044 thanked for this post
  16. #14
    May 2016
    Got all panel holes drilledpics for hot rod net0010.JPGpics for hot rod net0011.JPGpics for hot rod net0012.JPG and deburred. Will take them and other parts to powdercoater.
  17. #15
    Looks Great !
  18. #16
    May 2016
    pics for hot rod net0013.JPG Got some parts, but not the ones i need now. Owell always something else to work on.
  19. #17
    Jan 2016
    Did the crate engine come with the fly wheel? I Also see you got the boyd tank, are you going with the in tank pump? Looks good so far I will be keeping a close eye on your build as our power trains are very similar.
  20. #18
    May 2016
    BigB, yes engine cam with the stock flywheel, but i went with lightened billet flywheel - superior clutch, kevlar both sides - tilton 6000 clutch release - quick time bell and t56 trans from MDL.
    Checking bell to trans had to cut some off top two bolts. ARP bolts.
  21. #19
    May 2016
    Pilot bearing, one comes with engine, one with clutch. the ford one is thicker and looks better, but checking to make sure there is room.pics for hot rod net0014.JPG
  22. #20
    May 2016
    The bigger bearing worked good, came with engine but without checking you never know. Tilton throw- out bearing used up some time to set right, better to check more than once. Will go fast next time. Had to use dermalpics for hot rod net0015.JPGpics for hot rod net0017.JPGpics for hot rod net0018.JPGpics for hot rod net0019.JPG to make round hole out of flat sided slot.
  23. #21
    May 2016
    May 2016
    http://thefactoryfiveforum.com/showt...r-Conditioning
    For any one with AC in 33.
    FFR did not give info.
    Also link for getting belt on http://iihs.net/fsm/?dir=865&viewfil...%205.0L.pdfand off.
  25. #23
    May 2016
    Ol Skool
    upstate NY
    Nice job on the clutch stop. Are you going fat on the master cylinder to get shorter pedal travel or just limiting travel to avoid blowing out the bearing?
  27. #25
    May 2016
    To avoid blowing out tillion 6000 bearing. It is all setup, per directions put trany in gear and push pedal in till tran turns then 1/4 inch more. Put stop at that, i think that will be about as in pics.
  28. #26
    May 2016
    The other thing i had to run e-brake cables under the axle, not over as in plans to work.
  29. #27
    May 2016
    Going with 3/4 mc to have it easier to push.
  30. #28
    May 2016
    My engine lift bracket on PS will not clear, will try inside bolt on back.
  31. #29
    May 2016
    No room on back. Moved lift bracket forward one exhaust port, worked good with comalong from lift bar to back of trans. Will post pics later.
  32. #30
    May 2016
    OK motor and trams in to work out problems.
    Oil pan is to low, going to work on AC pump to get all the motor up and see if that will work. If close i will put some stanless on pan for armer.pics for hot rod net0036.JPGpics for hot rod net0039.JPGpics for hot rod net0040.JPGpics for hot rod net0042.JPGpics for hot rod net0044.JPG
  33. #31
    May 2016
    Had to move engine and trans -UP 1 inch + , Forward 1/2 inch, and over to DS 1/2 inch. Now i have 1/4 inch room engine to firewall, oil pan is even with frame and AC pump drive belt is clear of upper A-frame mount.pics for hot rod net0054.JPGpics for hot rod net0055.JPGpics for hot rod net0056.JPGpics for hot rod net0058.JPGpics for hot rod net0058.JPGpics for hot rod net0049.JPGpics for hot rod net0053.JPGpics for hot rod net0061.JPGpics for hot rod net0063.JPG
  34. #32
    May 2016
    Two morepics for hot rod net0045.JPGpics for hot rod net0046.JPG Dam it was easier to weld when eyes were younger!
  35. #33
    Ol Skool
    upstate NY
    Looking great Tom!
  36. #34
    Exciting build
  37. #35
    May 2016
    May 2016
    Senior Member jayguy's Avatar
    Las Vegas
    What about clocking the steering motor down a little? Looks like you wouldn't have to change it much.
  40. #38
    May 2016
    Did not want to lower steering motor.
  41. #39
    May 2016
    OK i had some problems with oil pan. It is the ford road racing pan and is made with hard metal. Did not like first job so cut it all out and did over, got to hot and warped the pan ! Dam i know better. Had to cut half of the flange from pan and spot weld to flat work bench , then heat and needle pen and weld small part around and do over till weled. Then check with die and fix leaks. O'well needed the practice any way? All good and on motor.pics for hot rod net0090.JPGpics for hot rod net0086.JPGpics for hot rod net0088.JPG
  42. Thanks tkafitz thanked for this post
  43. #40
    Ol Skool
    upstate NY
    If it isn't a challenge then it's no fun, right?
