Thanks Thanks:  12
Likes Likes:  114
Page 6 of 14 FirstFirst ... 45678 ... LastLast
Results 201 to 240 of 554
Thread: Toms 33
  1. #201
    May 2016
    North of sacramento Ca.
    Fabbed a hood brace for front. Needed because of big hole i cut for scoop.DPP_33_----000111.JPGDPP_33_----000112.JPGDPP_33_----000113.JPGDPP_33_----000114.JPG
    You have to take your time to get it to not hit other parts, it only goes one place!
  2. #202
    Does the prop rod fit with that brace?
  3. #203
    May 2016
    Have not done the prop rod, but will make something work.
  4. #204
    May 2016
    Been working on a bracket for front fenders and lights will be on fenders.DPP_33_-----000111.JPGDPP_33_-----000112.JPGDPP_33_-----000113.JPGDPP_33_-----000114.JPGDPP_33_-----000115.JPG
    Will remove radiator to remove and finish bracket.
    The fender will be sandwiched between brackets.
  5. #205
    May 2016
    Finished the front tender brace.DPP_33_------000111.JPGDPP_33_------000112.JPG
  6. #206
    Onalaska, TX
    Your garage looks like mine, but, I know where everything is, and if someone moves it.
  7. #207
    May 2016
    Any flat service just likes things on it!
  8. #208
    May 2016
    The front fenders and brace are all bolted together and work good!DPP_33_-------000112.JPGDPP_33_-------000113.JPG
    With all the parts in front of engine had to change the oil line holder and lower water hose(i don't like the ffr water line)DPP_33_-------000111.JPG
    I marked and fit body parts but when i bolted in the fender brace and hard bolted fenders it changed some of the fit(every time the radiator is off it changes some, it seems
    hard to get back in same place) sooo working on fitting hood - not bad but slow!
  9. #209
    May 2016
    Son holding headlight to see where to place them.DPP_33_-------3000111.JPGDPP_33_-------3000112.JPGDPP_33_-------3000113.JPGDPP_33_-------3000115.JPG
    OK i love the look!
  10. #210
    Quote Originally Posted by 1932 View Post
    OK i love the look!
    I haven't looked much at the headlights (and don't have mine yet) - are they the stock FFR ones?
  11. #211
    May 2016
    Not FFR. The headlights are stock 33 from Bob Drake.
  12. #212
    May 2016
    I ordered wheels and tires so after they come in i can work on mounting headlights then bumper brackets, more fun!
  13. #213
    After looking at how thin the housings were and the cup mounts were I decided not to use the FF lights either, they just seemed really
    flimsy. So I'm going with something smaller because I just don't like the Mr Magoo look anyway.
  14. #214
    Senior Member TDSapp's Avatar
    Frisco, TX
    I did the same after hearing from several folks that they were cheaply built. I just found, and bought, the head lights I want at the Goodguys show this weekend. They are not the big 9" headlights but were a great price. The buckets I got have LED driving\parking lights and the head light has LED turn signals built into them. I will post pictures on my build thread once they come in. They had to ship the gauges I bought so I had them ship everything so I would not have to carry them around.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
  15. #215
    Member tcollins's Avatar
    Oxford, Michigan and Scottsdale AZ (winters)
    Just noticed your build and that you are using a Coyote with the CJ intake...LOL I thought I was the only one? My company makes the intake for Ford so if you ever have an questions / issues, let me know. Anyway, I very interested in updating my headlights. I just finished my build and its the only thing I really unhappy with. I attempted to make the stock FFR pieces look better by powder coating and adding so ornaments, but they stay tight because the buckets are so flimsy. Anyway nice job, love the hood scoop! P.S. you may have issues with the coolant expansion tank if you are not using the Mustang system with the check valve. I making a custom tank now and will share details if you're interested?
  16. #216
    May 2016
    I am still looking for a place for the overflow tank!
    May need to make one to fit.
  17. #217
    Her is what I did with the hood prop given the CJ hood scoop. Added a rubber grommet and snapped it into the hood brace.
  18. #218
    May 2016
    Thanks, i have used up almost all room!
  19. #219
    That is a seriously awesome solution
  20. #220
    May 2016
    My hood did not fit good in back (worked on before) so i made it bolt down in back.Used cut outs from the dash, bent to fit hoodDPP_33_-------33000111.JPGDPP_33_-------33000116.JPGDPP_33_-------33000117.JPGDPP_33_-------33000115.JPGDPP_33_-------33000113.JPGDPP_33_-------33000114.JPG Hood is good now! Will make some handles to go with marker-turn lights.
    Doors are back on and work, will work on putting water fall in. Have to fit around roll cage.
  21. #221
    May 2016
    Worked on waterfall to make fit and working on four inch aluminum to go over top of waterfall and cab fiberglass to permanently hold top.DPP_33_-------333000111.JPGDPP_33_-------333000112.JPGDPP_33_-------333000113.JPGDPP_33_-------333000114.JPGDPP_33_-------333000115.JPGDPP_33_-------333000117.JPGDPP_33_-------333000116.JPG
    The aluminum will mach dash, I think the hot rod needs a little ruff old time look! We will see!
  22. #222
    May 2016
    Got the aluminum trem in , will pull and do some polishing. working on the parts to go around the roll cage, same aluminum.DPP_33_-------333-000113.JPGDPP_33_-------333-000114.JPGDPP_33_-------333-000116.JPG
    Body work to fix some work i did before.DPP_33_-------333-000111.JPGDPP_33_-------333-000112.JPG
  23. #223
    May 2016
    Paint colors - fenders & running boards and everything above stile line ford Bold Yellow 2, sides will be Mitsubishi Plasma purple Effect . Stile line will be Silver.
    One stage urethane for inside and base & clear coat outside.
  24. #224
    May 2016
    Been working on top i think it is close. I have had problems with this running board-to short and did not mate with fender. Will see next week if i cut the boards and rear fenders. get wheels and tires .DPP_33_-------333-000113.JPGDPP_33_-------333--000115.JPGDPP_33_-------333--000113.JPGDPP_33_-------333--000114.JPG
  25. #225
    May 2016
    Ol Skool
    upstate NY
    Hey Tom, just curious, how far off was the running board? Just the one side?
  27. #227
    May 2016
    The DS was ok but PS was over one inch short, and did not like fender to board fit. So i smoothed out both sides. Not FFR. Get wheels & tires on 9th, will see if more cutting is in order!
  28. #228
    May 2016
    Did not like how the front fender and running board came together so i ground filler out and made it straight looking down the side.IMG_7928.JPGIMG_7929.JPGIMG_7930.JPGIMG_7931.JPG
  29. #229
    May 2016
    New wheels & tires!
    Worked on fiting trunk lid. For all that have yet to do trunk lid (1) Put hinges on BEFORE body (2) work sides so lid fits in but not gaped, then work on top to get lid to fit with body sides, take your time mine fit good!IMG_7933.JPGIMG_7934.JPGIMG_7935.JPG
  30. #230
    May 2016
    I wanted the stock trunk handle-locking-. To make it work took Three spacers dam close to the right length - for any spacing- and a piece of square tubing with the inside rounded and put in with short strand filler to make the lock work.IMG_7939.JPGIMG_7940.JPGIMG_7942.JPGIMG_7945.JPGIMG_7948.JPG
    Will make the catch later.
  31. #231
    May 2016
    Built the other part of trunk latch. wielded base to the 1 inch square tube then made the latch part out of rock crusher wiper, it is rubbery plastic, did not want metal to metal.IMG_7949.JPGIMG_7952.JPGIMG_7953.JPG
    Ok all good!
  32. #232
    May 2016
    First time for wheels on.
    Cut the boards and rear fenders, want them just outside of tire, so i think i need to do the alignmentIMG_7954.JPGIMG_7955.JPGIMG_7956.JPGIMG_7958.JPGIMG_7960.JPGIMG_7962.JPGIMG_7965.JPGIMG_7966.JPG
    Looks like need to lower back..
  33. #233
    Boy, that is looking wicked! Fantastic job so far.
  34. #234
    Gatineau, Quebec, canada
    If I could suggest a trick for the split fender in the back, I would suggest feathering each cut edge, then you take a piece of arborite that is at least a couple inches wider than the split on each side, cut it as long as the split, wax the arborite only with a de-molding wax, lay it over the finished side of the split, attach to the top of the fender so its very secure (if using screws predrill the arborite and not the fiberglass and use round head screws, these can be quickly patched after), remove the fender, flip it over, paint in some Gelcoat (if you have some if not a nice wet first layer of fiberglass) on the arborite up to the edge of the existing fiberglass, let the Gelcoat set, then laminate it together with a few layers of mat starting with no overlap on the first layer only (1 oz. mat) and then adding an inch of overlap on subsequent layers (suggest 1 oz. mat, then 6 oz. cloth, 1oz. mat, 6 oz. cloth minimum, I would add another layer of mat and cloth). Since the fender is basically flat this will save a lot of time in aligning and finishing work and will give you the strongest connection between the two. Have fun!!
  35. #235
    Ol Skool
    upstate NY
    I kind of did what AJT is saying. I made the hidden inside part more structural and squeezed the glass with a sandwich of 2 waxed pieces of leftover paneling. I could only do a practical bend of 50% of the fender so I did the top first for gravity assistance and I had long reach welding clamps on it to get the inside overlaps clamped. Almost identical approach to Tom's except I cut a curve at the front and narrowed my running boards.
    I didn't have gelcoat, but that would have been nice.
    Caution: My Fender width with 345's matches the inside of my aluminum trailer...oops...ship in a bottle syndrome. But, I am set up to swap between the original rears and the extra wide dually option so if I trailer it I can put the old set back on.
  36. #236
    May 2016
    May 2016
    The alignment was not bad after i got the program right!
    After that i saw that the fenders were off, had to lower the PS with spacer inside on fender brace, all good.
    Getting ready to glass rear fenders and boards.IMG_7976.JPGIMG_7979.JPGIMG_7982.JPG
  38. #238
    May 2016
    All glassted upIMG_7989.JPGIMG_7985.JPG now on to cleanup and finish. Need to make board frame to fit IMG_7986.JPG
  39. #239
    May 2016
    Running boards turned out to be more work because of them being cupped, i have them flat and at 180 paper. The fenders have the first primer, will see how good they are tomorrow.IMG_7992.JPGIMG_7992.JPGIMG_7995.JPG
  40. #240
    May 2016
    Put fenders and boards on and needed to cut the back and tuck it in to match fender not go around outside IMG_7996.JPGand on front of boards need to round or blend this IMG_7998.JPG
