0
0
Factory Five Roadster MK II For Sale
Factory Five Racing Mk II Roadster (FFR 5056) SOLD!!
This is a quality build using only the best components. My goal was to build the car and maintain the look of the original, while implementing performance and reliability enhancements.
This was a labor of love and was, in no way, rushed to completion (Yes, it’s a Mk II Roadster). The body work and paint were completed in February 2014 by Whitby’s in Greensboro, N.C.
Everything works, and the car is a thrill and a pleasure to drive. If you are looking for a car that is fun to drive, reliable and great looking, this is one you should consider.
Pennsylvania Titled, Registered. Pennsylvania Inspection completed on 5/27/16.
Current mileage is just over 4500.
I have saved every receipt for this build and will provide them to the new owner. I also have a build book that outlines details of the build that may be useful for future troubleshooting or upgrades.
Paint Color:
Guardsman Blue
Wimbledon White Stripes
Engine:
5.0 Liter EFI (New / Non-donor)
E-303 Cam Shaft
GT-40P Heads
GT-40 Intake
70 mm Throttle Body
1:6 Roller Rockers
24 Lb Fuel Injectors
Mass Air Flow meter adjusted for Throttle body and Injectors
Ceramic Coated Ford Motor Sports Headers
Factory Five Racing Catalytic Converters (Ceramic Coated by Jet Hot)
Ceramic (Jet Hot) Coated Side Pipes
Ceramic Coated Side Pipe Shields
MSD Billet Distributor
MSD Coil
March Under -Drive Clear Coated Polished Pulley System
Canton 8 Qt. Oil Pan
Breeze Aluminum Radiator
Taylor Racing ignition wires
Cobra Polished Aluminum Valve Covers
Edelbrock Polished Aluminum Water Pump
BBK Adjustable Fuel Regulator and Gauge
Energy Suspension Motor Mounts
New Ford Racing Mini-starter
Ford Racing 90 Degree Oil Filter Adapter
Transmission:
5 Speed T-5
King Cobra Clutch and Pressure Plate
Clutch Cable Adjuster
Pro 5.0 Shifter
3:55 Rear End Gears
Interior:
Classic Instruments Gauges (Electronic)
Vintage Air Heater
Honda S2000 Start Button
Herbs Interior Door Panels
Russ’s Garage Turn Signal System
Finish Line Cobra Steering Wheel Center Cap
Cobra Floor Mats (Finish Line)
Mike’s E-Brake Trim Ring
Factory Five Leather Seat Option
Factory Five Tonneau Cover
Wood and Leather Steering Wheels
Mike’s Under Dash Panel
Russ’s Throttle Pedal (With matching brake and clutch pedals)
Cobra Earls extended passenger foot box
Mike’s E-Brake handle cover
Adjustable Driver’s Side Seat Track
Steering & Suspension:
Flaming River 15:1 Steering Rack
Factory Five 3 Link Suspension
Factory Five Tubular Lower Control Arms
PS Engineering 15” Wheels
BF Goodrich TA Radial tires
Pro Shocks
Miscellaneous:
Windshield Wipers
Heater
Fary Five Hood Hinge
Chrome Roll Bar
Trunk Lid Support (Finish Line)
FFMetal Battery Box
Hella Horns
Chrome Fire Extinguisher
Finish Line Roll Bar Grommets
Ford Motor Sports Aluminum Axle Girdle
Flaming River Steering Rack
Optima Red Top Battery
Powder Coated Frame
Tri-States Stainless Steel Brake Lines
Polished Aluminum Side Louvers (Finish Line)
Summit Brake Proportioning Valve
Factory Five Wind Wings and Sun Visors
Finish Line trunk lid support
New Fuel Tank
New Fuel Level Sender
Chrome Windshield Mounted Rear View Mirrors
Finish Line Polished Side Louvers
Custom Polished Radiator Shroud that replicates the original
New 427 style shifter and shifter knob
Hidden trunk hinges (Breeze)
New blue Weathershield car cover
Price:
$33,000
Reason: Car is Sold
Very interested in your car if you still have it. My cell is 828 699-3841, Doug in NC
Please let me know.
Administrator
Beautiful car, price very well! It should go quickly. Good luck!
- You may not post replies
- You may not edit your posts
Forum Rules
