Question to Coyote experts - what clutch are you using?
I have a Coyote - TKO 600 combo with the recommended FRPP Centerforce clutch as per the FFR recommended parts list. I have just under 10k miles and need to replace my clutch (beginning to slip slightly at higher speeds when hitting the throttle). I have checked the cable adjustment and clutch fully engages. I am thinking of change to a stock Ford clutch if possible as I believe it may provide longer life. I was hoping to get 20k mi on my clutch and I am surprised I have to replace so soon - no track time and only the occasional hot launch.
Has anyone changed a clutch with a Coyote without removing the engine & trans from the car? Or can I change the clutch by loosening the engine mount bolts and tilting the engine / trans to remove the trans & clutch??
Any suggestions re best clutch to use for my replacement?
Thx in advance
