Results 1 to 4 of 4
Thread: 289 Tail Light
    Talking 289 Tail Light
    HELP. I need a little assistance in the wiring of the tail lights on the 289. The light assemblies have two wires but the harness has four (the tail light, turn signal and brake light). How do you wire these in to have functioning tail lights?
    Nov 2015
    Hello,
    Per the 289 supplemental instructions: Because the tail light is both the stop and turn signal the tail light converter (included) must be wired into the harness,
    do this under the dash. On the light, the white is the ground wire and the black is the running light wire. Connect the light wires to the chassis harness.
    Greg Hoy
    Factory Five
    Senior Member Raceral's Avatar
    Stoneville NC
    Al Adkins
    Certified "Kool Aid" drinker
    No need to reinvent the wheel. Your 289 kit should have come with a trailer converter to make your single lamp lights work. Follow the instructions with the converter and you should be good.
    Mark Twain
