0
0
These can't be the right electrical pins for these connectors.... are they?
This is what FFR sent me for the front turn signals. The pins do not fit into the connector housing all the way. The fit part of the way but are too big to fit all the way in. There is a lacking tab in the connector housing but it is not what is preventing these from going in further. I've even used a small screwdriver to bend the locking tab out of the way and it doesn't make a difference.
Does this picture look like what you received and successfully used?
Answered my own question..... again. The terminal pins they sent me as shown in the pic above are not the right pins for the connector. I rummaged through the remains of my old donor wiring harness and was able to de-pin a few of the correct terminals and use them in these new connector housings.
Ffr has never been able to supply the correct number type of pins for most of there connectors on the 818. Someone really needs to help the shipping department. They would save a bunch of money by doing things correctly.
Originally Posted by
07FIREBLADE
They've sent me a handful of things I needed because they sent the wrong stuff and they sent me a handful of things I didn't need (and never asked for) because they mixed things up.
- You may not post replies
- You may not edit your posts
Forum Rules
