Hi Hindsight,
I just completed my alignment, with the same goals as you post starting out. (although now I am wondering if I should have done 5 degrees of caster).
I wrote up a thread on the "Alignment process for the 818S" under the suspension threads. Could you take a look and see if I missed anything. Hoping to generate a process with one place for all the info.
Second question. I used 15.75 in for lateral link length. Mine measured 16 1/8 (but off a wagon). I am using the aluminum LCA's up front, and wanted to use sedan settings as I have adjustable lateral links in back. Do you know what the right length for sedans is ?
Thanks, your alignment info really helped me. Thanks for posting.
