It was bound to happen. I took the car out for a ride to move it from home over to my shop at the airport about ten miles away, but decided to go the long way. I made a stop in one of the nearby towns along the river (down in a valley) and wouldn't you know it - I started it up in front of an admiring crowd, put the clutch down to move it into reverse, heard a very slight "pop" and the clutch pedal flopped to the floor.
I should have known better, but I used the "heavy duty" clutch cable that came with my BBK aluminum quadrant instead of ordering an OEM Ford cable. I did that in part because I thought that the one they supplied would be a good alternative and I already had two others - both offshore aftermarket ones that I didn't want to use due to all the stories of those breaking. Oh well, guaranteed I'll go with the Ford part now - and I'll buy two and keep one in the trunk for road trips.
Back to the story, though...... to the dismay of those gathered around, I got out, pushed the car back out of the parking space, and started it as it rolled down the hill towards the exit. Once it was up to speed, I clicked it into first gear, then proceeded to drive nearly fifteen miles back to the hangar... without a clutch.... and up out of the aforementioned valley. I may have rolled a couple of stop signs, but otherwise a safe trip.
I figure I was lucky - I'll wait to be "saved" by my car buddies when 7074 is truly dead on the side of the road.
