Results 1 to 11 of 11
Thread: Windshield wiper alternatives - ideas
    Feb 2013
    Bowling Green OHIO
    Decided to start a new thread for this since there are probably other states with the requirement to have wipers other than ohio. I had no intentions of putting wipers in but need to do something to meet the code: just looking for some simple ideas for the inspection. I will include the posts from the other thread they were in.
    So I called the state highway patrol, cause I am getting ready to get my inspection. I am bummed, he asked if it had wipers, It doesn't and I do not want to put them in, there is no reason to on a convertible with out a top In my opinion but its in the ohio revised code so he said it needs it, even if there manual. does a wiper arm stashed behind the seat that you grab, stand up, and swipe across the windshield foot the bill?
    On the positive side he said we don't need a third brake light.
    Anyone do any manual wipers? that could be temporarily "installed"
    Feb 2013
    Bowling Green OHIO
    Bob in cinci did this:
    Doug,
    http://www.cabelas.com/product/EXTRE...Q&gclsrc=aw.ds
    My wiper is the least intrusive and doesn't need any hood trimming.
    http://thefactoryfiveforum.com/attac...6&d=1441837088
    The other thing that surprised me was the need for 4" tall 60" wide bumper than I had to add.
    Stop by if you get down this way.
    Feb 2013
    Bowling Green OHIO
    Quote Originally Posted by dougkirkbride View Post
    I like it bob... How do you actuate it? Under the dash?
    Yours is not to intrusive but I really like this one. I could even keep a spare behind the seat...Click image for larger version. Name: image.jpeg Views: 9 Size: 47.3 KB ID: 56021
    Your are going to keep your spare grandma behind the seat?
    Sorry if I misled you, mine is electric. Here is the motor. Click image for larger version. Name: wipe.jpg Views: 8 Size: 56.1 KB ID: 56024
    Feb 2013
    Bowling Green OHIO
    this is what I really want to do..........
    http://thefactoryfiveforum.com/attac...1&d=1468288563
    IMO anything that may help you stay out of an accident should be considered. You may be willing to take the risk, but if you are going to have a passenger, are you ready to play what if for the rest of your life over a low cost mod?
    Leesburg, VA
    There are a few reasons I can see for keeping a wiper (even for a summer car that won't be driven in the rain):
    1. Unexpected storms/rain happen
    2. Unexpected water spray from other drivers hitting a puddle of water or sprinklers (I've actually gotten sprayed by some of these on my local roads before)
    I also didn't see the point of putting in a wiper on a car that wasn't gonna be driven in the rain but then I thought it sure would be nice to maintain visibility in case the unexpected happens. I used the same wiper motor as Bob and made a custom bracket.
    I'm sure you've thought of this, but products like Rain-X make a HUGE difference. I have windshield wipers on mine(The FFR kit), and I never use them. If it rains, the Rain-X makes the windshield wipers pretty much unnecessary - unless it's a huge downpour. I try not to use the wipers if I can help it. It's a fairly fragile set-up wiper system, in my opinion. I've had it break before. I'd rather not risk it breaking again, so I use it only when absolutely necessary. (and for passing inspection)
    Check my build thread - I have pics showing how I did mine. Very temporary, requires no cutting, and after my inspection, I removed all traces of the wiper within 5 minutes.
    Mar 2014
    Edwardsville, IL
    In Illinois I got away with putting the FFR wiper kit in, which is about 4 drilled holes and rivnuts. I didn't cut the hood. I don't think the hood is required. I took the wipers back out after the inspection. The downside is your wiring has to be good and you have to drop the $225 on the wiper kit. This is an easy solution. Not necessarily cheap.
    Lansdale
    I just finished my build, check out my wiper. minimal hood trimming using the subaru wiper assembly.
    http://thefactoryfiveforum.com/showt...818s-248-build
    FFR 818s #248 received 10/24/14
    first start 3/9/15 https://youtu.be/aRivN83ym-0
    first gocart 3/28/15 https://youtu.be/0Cq9LLzM_40
    first auto-x 4/12/15 https://youtu.be/4ada081tuks bloopers https://youtu.be/ZnBk0C-9uxE
    Body on auto-x Pocono pa 9/20/15 https://www.youtube.com/watch?v=chwtszG7vyg
    PA Titled and inspected 7/15/2016
    Feb 2014
    Asheville, NC
    My ghetto solution was cheap, reversible, and passed in NY.
    Frank - Build thread
