Windshield wiper alternatives - ideas
Decided to start a new thread for this since there are probably other states with the requirement to have wipers other than ohio. I had no intentions of putting wipers in but need to do something to meet the code: just looking for some simple ideas for the inspection. I will include the posts from the other thread they were in.
So I called the state highway patrol, cause I am getting ready to get my inspection. I am bummed, he asked if it had wipers, It doesn't and I do not want to put them in, there is no reason to on a convertible with out a top In my opinion but its in the ohio revised code so he said it needs it, even if there manual. does a wiper arm stashed behind the seat that you grab, stand up, and swipe across the windshield foot the bill?
On the positive side he said we don't need a third brake light.
Anyone do any manual wipers? that could be temporarily "installed"
Bob in cinci did this:
Doug,
http://www.cabelas.com/product/EXTRE...Q&gclsrc=aw.ds
My wiper is the least intrusive and doesn't need any hood trimming.
http://thefactoryfiveforum.com/attac...6&d=1441837088
The other thing that surprised me was the need for 4" tall 60" wide bumper than I had to add.
Stop by if you get down this way.
Quote Originally Posted by dougkirkbride View Post
I like it bob... How do you actuate it? Under the dash?
Yours is not to intrusive but I really like this one. I could even keep a spare behind the seat...Click image for larger version. Name: image.jpeg Views: 9 Size: 47.3 KB ID: 56021
Your are going to keep your spare grandma behind the seat?
Sorry if I misled you, mine is electric. Here is the motor. Click image for larger version. Name: wipe.jpg Views: 8 Size: 56.1 KB ID: 56024
dougkirkbride
IMO anything that may help you stay out of an accident should be considered. You may be willing to take the risk, but if you are going to have a passenger, are you ready to play what if for the rest of your life over a low cost mod?
There are a few reasons I can see for keeping a wiper (even for a summer car that won't be driven in the rain):
1. Unexpected storms/rain happen
2. Unexpected water spray from other drivers hitting a puddle of water or sprinklers (I've actually gotten sprayed by some of these on my local roads before)
I also didn't see the point of putting in a wiper on a car that wasn't gonna be driven in the rain but then I thought it sure would be nice to maintain visibility in case the unexpected happens. I used the same wiper motor as Bob and made a custom bracket.
I'm sure you've thought of this, but products like Rain-X make a HUGE difference. I have windshield wipers on mine(The FFR kit), and I never use them. If it rains, the Rain-X makes the windshield wipers pretty much unnecessary - unless it's a huge downpour. I try not to use the wipers if I can help it. It's a fairly fragile set-up wiper system, in my opinion. I've had it break before. I'd rather not risk it breaking again, so I use it only when absolutely necessary. (and for passing inspection)
Moonlight Performance
Check my build thread - I have pics showing how I did mine. Very temporary, requires no cutting, and after my inspection, I removed all traces of the wiper within 5 minutes.
In Illinois I got away with putting the FFR wiper kit in, which is about 4 drilled holes and rivnuts. I didn't cut the hood. I don't think the hood is required. I took the wipers back out after the inspection. The downside is your wiring has to be good and you have to drop the $225 on the wiper kit. This is an easy solution. Not necessarily cheap.
I just finished my build, check out my wiper. minimal hood trimming using the subaru wiper assembly.
http://thefactoryfiveforum.com/showt...818s-248-build
My ghetto solution was cheap, reversible, and passed in NY.
