Results 1 to 5 of 5
Thread: Factory Five Roadster MK III For Sale
    Hi All,
    I have a Factory Five MK3 Roadster for sale.(chassis #6445, VIN: F5R1006445RD) I am the second owner. The first owner/builder bought the kit in 2008 and finished/registered it in 2010. It is registered and titled in Texas as a “2010 Assembled.” The car is a donor build, but nearly all donor parts were rebuilt/restored.(See below) I have all receipts and documentation, including the original assembly manual. Also included is a custom car cover with lock. The current mileage is just under 6700.
    I’m selling because I just got married, and I seem to be running out of places to park . . . : (
    SOLD. THANKS!
    Engine:
    1989 Ford Mustang 302. It was rebuilt and bored .030” over when the Cobra was built. The engine was rebuilt with the following:
    New Edelbrock dual plane Performer RPM manifold
    New Holley 4150 - 600 CFM Holly DP
    New Ford racing E303 cam
    New Ford racing X306 heads
    New Cobra valve covers
    New cam bearings, lifters, push rods, rocker arms
    New oil pump
    Stock headers
    Ceramic coated side exhaust and J-pipes
    Clutch:
    Re-surfaced flywheel
    New king cobra clutch, pressure plate, throw-out bearing, and pilot bearing
    New clutch cable and Ford racing clutch adjuster
    Transmission:
    T-5 transmission rebuilt with Ford Racing part number# M-700-A
    Rear axle:
    8.8 solid axle with new Ford Racing 3.55 gears
    Rebuilt Traction-Loc, new axle, pinion and carrier bearings
    Electrical:
    Ron Francis chassis harness and fuse box
    Summit racing ignition control box with rev limiter
    Battery cut off switch
    Rear mounted FFmetal battery box
    180 degree automatic cooling fan switch with manual override
    Fuel system:
    Stock Mustang tank
    External electric fuel pump
    Fuel pressure gauge on carburetor
    Chassis, Suspension, Brakes and Wheels:
    Black powder-coated frame
    Koni coilovers (500 lbs springs in front, 350 lbs springs in rear), adjustable rebound valving
    Factory Five 3-link rear suspension with welded on top link arm
    Factory Five tubular front lower control arms
    5 lug hubs
    Manual front and rear disc brakes (SN-95 Mustang rear disc brakes)
    Adjustable brake bias valve
    Power steering
    Powder-coated Team 3 aluminum 5 lug Halibrand wheels with replica knock-off spinners. (15x8 front, 15x10 rear)
    Goodyear Eagle GT 235/60/15 front, 295/50/15 rear
    Body and exterior:
    Rolled cockpit edges and rolled wheel wells
    Feather fill primer, PPG DP90LF epoxy sealer, PPG Black base coat/clear coat paint
    Wet sanded and professionally buffed
    Entire under body has truck bed liner coating
    Dual roll bar with trim rings, powder-coated black
    Tangent blind roll bar kit
    Black front and rear quick jacks
    Visors and wind wings
    Factory five hood hinge kit
    Replica Parts trunk support kit
    Factory Five windshield wiper kit
    Interior:
    Low back vinyl seats with Breeze angled, adjustable seat mounts
    Sound deadening and heat shielding throughout entire cockpit (waterproof)
    Door vinyl side pockets
    Vintage gauges
    Dual headset Bluetooth receiver, mounted under dash (to access Pandora, Spotify, etc via phone)
    Heated seats (three settings for each: High, Low, and Off)
    Please let me know if you have any questions.
    Thanks!
    Patrick
    (c) 214-724-6839
    20160703_093122.jpg20160703_093127.jpg20160703_093134.jpg20160703_093143.jpg20160703_093150.jpg20160703_093156.jpg20160703_093202.jpg20160703_093213.jpg20160703_093220.jpg20160703_093229.jpg
    where in Texas are you ?
    Member Georg's Avatar
    Jan 2015
    Hi Patrick,
    Congratulation to your marriage! Too bad you needed to sold your other beauty... Can I ask you how much was the final deal?
    Thanks, Georg
