0
0
Murray Turbo Seal Clamps and Dual Bead Clamps
Colonel Red Racing is now a Murray Clamps Authorized Reseller.
Murray Constant Tension Turbo Seal Clamps – With a convoluted heat-treated band that provides spring-like tensioning effects for thermal cycling hose applications.
Murray hose clamps are designed to compensate for the effects of heating and cooling, and the compression set of the hose. Murray's convoluted spring-action outer band is the solution.
Murray’s unique “DUAL BEAD SHIELD” concentrates band-sealing pressure, increasing performance up to 30% compared to standard smooth liners. Flanged edges protect soft hose compounds from abrasion and wear.
The unique Dual Bead Shield provides superior sealing pressure via its two raised ribs and flanged edges to eliminate damage to the hose when tightened.The unique inner liner also concentrates band-sealing pressure, increasing performance up to 30% compared to standard smooth liners. Flanged edges protect soft hose compounds.
Murray Constant Tension Turbo Seal Clamps evenly distribute the clamping force completely around the piping makes them superior to t-bolt or regular worm clamps. These clamps are excellent for turbo boost applications.
Electropolishing improves weld strength, which leads to improved performance, improved corrosion resistance, and enhances appearance with a more even finish.
This clamp is used in automotive, off-highway, agriculture, heavy duty, aircraft (non-flight critical applications only), and military industries and can be found on turbo chargers, tanks, air-to-air, cooling and fuel lines.
Murray Clamps are widely used in WRC Racing around the world. See the clamps in the image of the 2016 Subaru Isle of Man WRX race car that set the lap record!
Unlike T-Bolt Clamps that have a very limited range, these Turbo Seal Clamps fit over a wider range of hose sizes.
Turbo-Seal Material Specifications
Band Material: Special proprietary grade of stainless with excellent spring properties
Housing Material: 300 Series Stainless
Shield Material: 300 Series Stainless
Screw Material: 300 Series Stainless
Rated Ultimate Torque: 75in.lbs. min. (8.5Nm)
Recommended Installation Torque: 50in.lbs. (5.6Nm)
Turbo-Seal tension clamps are offered in several sizes.
Part |
Inches |
MM |
Price |
TSS16S30EP |
1-1/5" to 1-5/8" |
30mm to 41mm |
$9.25 |
TSS20S30EP |
1 3/8" to 1 7/8" |
35mm to 48mm |
$9.27 |
TSS28S30EP |
1 5/8" to 2 3/8" |
41mm to 60mm |
$9.58 |
TSS32S30EP |
1-13/16" to 2-5/8" |
46mm to 67mm |
$9.85 |
TSS36S30EP |
1 31/32" to 2 7/8" |
50mm to 73mm |
$10.03 |
TSS44S30EP |
2 1/2" to 3 3/8" |
64mm to 86mm |
$11.04 |
TSS48S30EP |
2 3/4" to 3 5/8" |
70mm to 92mm |
$11.59 |
Factory Five Forum members take 10% off your total price. This is for Factory Five Forum Members only! Shoot me a PM to purchase. There is a $3.50 shipping charge that applies only to the first clamp, all additional clamps are free shipping.
OR, you can buy them on my ebay Store here: https://www.ebay.com/str/colonelredracing
However the Ebay store won't be the best pricing for large orders because I can't build in the FF Forum 10% discount or the best shipping deal.
Murray Dual Band Clamps:
Basically the same clamp minus the spring. Great for cooling lines and anywhere you would use a standard worm clamp, only better!
Part |
Inches |
MM |
Price |
DB20SS |
11/16" to 1 5/" |
17.5mm to 41mm |
$3.64 |
DB28SS |
1 3/16" to 2 1/8" |
31mm to 54mm |
$3.79 |
DB36SS |
1 11/16" to 2 5/8" |
42mm to 663mm |
$3.98 |
DB44SS |
2 3/16" to 3 1/8" |
56mm to 79mm |
$4.25 |
DB48SS |
2 7/16" to 3 3/8" |
62mm to 85mm |
$4.41 |
DB56SS |
2-15/16" to 3-7/8" |
74.6mm to 98.9mm |
DB64SS |
3 7/16" to 4 3/8" |
88mm to 111mm |
$4.67 |
DB72SS |
3 15/16" to 4 7/8" |
100mm to 123mm |
4.72 |
Tech Tips From Colonel Red Racing:
Silicone Hose Outer Diameter Sizing:
Use this chart to determine which Murray clamp to use on your silicone turbo hose connections. For example a 2 1/2" intercooler pipe uses a 2 1/2" silicone ID connector, but since the silicone outer diameter is larger you need a larger than 2 1/2" clamp. Silicone hoses are NOT all the same thickness so you can measure the outer circumference of yours and look it up on the chart to be sure you get the right size.
1.75” Hose=44mmID=2.07”OD=53mmOD=6.5” Circumference=166mm Circumference.
2.0” Hose=51mmID=2.32”OD=59mmOD=7.29” Circumference=185mm Circumference
2.25” Hose=57mmID=2.57”OD=66mmOD=8.07” Circumference=207mm Circumference
2.50” Hose=63.5mmID= 2.82”OD=72mmOD=8.85” Circumference=226mm Circumference
2.75” Hose=70mm ID=3.07”OD=78mmOD=9.65” Circumference=245mm Circumference
3.0” Hose=76mmID=3.32”OD=85mmOD=10.43” Circumference=267mm Circumference
3.13” Hose=80mmID=3.45”OD=88MMOD=10.84” Circumference=276mm Circumference
3.25” Hose=83mmID=3.57”OD=91mmOD=11.22” Circumference=286mm Circumference
Intercooler Piping Tech Tips
The Constant Tension clamps are good for Intercooler piping and the CAI inlet on the turbo. The Dual Bead clamps work great on typical coolant hoses and other applications where the temps move slower and are more stable.
Be aware, if your intercooler pipes have oily residue in them and inside the silicon coupler you have to clean them really well, to make sure oil is gone. No clamp will hold an oily IC pipe under boost.
And after cleaning off the oil a quick spray of Aqua Net Extra Hold hairspray does an amazing job. Spray the outside of the IC or Intake piping with Aqua Net Extrra Hold, then slip the clean silicone hose coupler over it. You have a few minutes to adjust the pipes before the AquaNet sets up. Since we started using the constant tension clamps + Aqua Net Extra Hold we've never popped off a IC pipe in our races.
Colonel Red Racing
Owner: Colonel Red Racing
eBAy Store:
http://stores.ebay.com/colonelredracing
818R ICSCC SPM
