Results 1 to 6 of 6
Thread: O-Ring compatibility for fuel?
    Need to replace the o-rings on my inline fuel pump case. I know Viton is compatible with direct contact to fuel, is Nitrile?
    Nitrile, also known as BNR and Buna-N, is good for petroleum fuels.
    Vermilion,OH
    Nitrile in today's fuels will swell considerably in a short time. This comes from years of experience in oil and gas pipeline work. Viton is the best choice.
    thanks!
    Here is a source for this type of info
    http://www.mcmaster.com/#orifices/=13fmx2m
    Note the column on the left "For use with". These guys are great for info on nearly any material.
    This is the ref I've used for a while on everything to do with oring seals.
    http://www.sealdynamics.com/o-ring-reference.pdf
