Results 1 to 11 of 11
Thread: First Start Birthday!
    Chino Valley, Arizona
    Gave my wife a first start deadline of my 53rd birthday last Saturday. I was ready to go about six days before, but my bride wanted me to wait....gave me an opportunity to triple check wiring, coolant and fluid leaks, etc. - but hard not to turn the key. She (Medusa) started up, rough at that - but no major leaks, fires or anything to catastrophic. The motor is a fuel injected 347 with 10 degrees of timing and I am using a Pro-M engine management system (ECU). It kept throwing a distributor Hal sensor or shutter OB2 code for my new Davis distributor. Apparently these two components in concert sense cam position and trigger firing. According to Pro-M, seems a lot of aftermarket shutters are out of tolerance and most Hal's effect sensors are junk. I am told the Ford distributor has the best sensor and its shutter is to specs. Pulled my shutter and the eight rotating fingers were measured significantly out of tolerances. New shutter from Pro-M and Ford OEM stator ordered. Guess I will have the best of both worlds - sexier looking distributor housing and better internals. Will keep you posted - technical issues uploading video & pics, but was great birthday!
    Congrats on getting the first start. That's a major mile stone and feels good, too! Happy 53rd B day. Hope you get your distributor signal issues behind you.
    Good luck,
    WEK.
    Thanks - hope to get my new stator and shutter installed soon!
    Senior Member rmiller64's Avatar
    Ferndale, WA
    Congrats Chris on the mile stone!
    Rick
    #8442 MK4 Complete kit, 331 Stroker, T5, 3.73 Posi 3-Link, 15", Goodyear Billboards
    Order 8/22/14 Del 11/7/14 First Start 3/9/15 Go Cart 3/14/15 Paint 2/25/16
    http://thefactoryfiveforum.com/showt...MK4-8442-Build
    Thanks Rick! Was able to rebuild my distributor without taking it to a machine shop. Hopefully the shutter is here on Monday and I can continue tuning...
    May 2013
    Slidell la
    Congrats
    Mk4 # 8834 delivered 03/20/16 2015 IRS wildwood brake upgrade, 18"x9" front 18"X11" rear halibrand wheels, 390 FE, tko600
    Thanks - replaced both and it runs like a champ!
    Senior Member Rotorcraft's Avatar
    Sep 2011
    Snohomish,Wa
    Nice work, Chris!
    Thanks Bud!
    Ferndale, WA
    Good deal Chris Going to get down to see you soon. Jeff and I need a road trip
    Rick
    Sounds great - look forward to meeting you in person. I spent all afternoon yesterday fine tuning her with my laptop and she purs liked a big cat!
