Results 1 to 5 of 5
Thread: Installing Carpet
    Installing Carpet
    At some point I will install carpeting. But for awhile I will just have the aluminum. I would like to paint it satin black until it's carpeted. But will it be difficult to get the carpet to stick if the aluminum is painted?
    Bill
    Senior Member dallas_'s Avatar
    Dallas, TX
    Probably.
    You might want to consider plasti-dip. You can peel it off easily and it would be a good look for the interior.
    FFR 7123 tilt front, Levy 5link/wilwoods/LCA's, webers.
    SL-C, LS3 525, Mendeola SDR5,
    Thanks dallas
    Apr 2015
    Irving, TX
    I have to disagree...every production car ever built has had paint, they glue carpeting to many cars, many surfaces. Glue sticks to paint just fine. The trick is getting paint to stick to aluminum. You will have to read up on the different methods such as alodine, epoxy, or prekote. (Prekote is non toxic, and the Air Force is using it to paint more of their planes nowadays)
    Super Moderator oldguy668's Avatar
    Painting the aluminum is more work than fitting and attaching the carpet. If you are not ready for the permanent carpet, buy some cheap stuff. You can use it as a template when you get ready for the good stuff.
    "Loyalty to the country always. Loyalty to the government when it deserves it".
    Mark Twain
