Thread: Missing some donor parts
    Just picked up my 818S kit. In going through the manual I have discovered I am missing some bits from my 06 Donor pallet. Specifically, the hood hinges( not listed as needed on the FFR website) and the clevis pins for the brake and clutch pedals. Before I go searching on Ebay, anyone have a spare set of hinges and pins. Can someone measure the pins and give me the specs if I need to buy some. Still unpacking boxes and doing inventory, taking a deep breath before taking on this project
    thanks
    Tom
    Banned
    Can't help you there, but for a long time the fuel level sending unit wasn't on the list as the original FFR tank didn't use it. Might want to make sure you have that as well. I know I had to get one off ebay and re-splice it into the wiring harness as that connector had been dieted already.
    Leesburg, VA
    I did a quick search for the clevis pin and came up with this part number: 905200017. I'm not sure what year your master cylinders are from though. The subaru dealer will probably have these for cheap and they'll be the right size.
    Thanks, got the fuel level sender. Will check with local Subaru dealer for pins. Anyone with hood hinges or Ebay.
    Feb 2014
    Asheville, NC
    if you have a local junkyard you can probably find hinges fairly easily. They'll be just a few bucks then
    Frank - Build thread
    Freeport, ME
    Just buy Craig's hinges, they look much better being billet aluminum Zero DB Motorsports
    Dan
