ISIS Power
Page 2 of 2 FirstFirst 12
Results 41 to 60 of 60
Thread: Bump steer
    QC, Canada
    But changing the length of that link affects directly the parallelism of the lower Subaru lateral links and when those aren't parallel, it apparently causes a lot of driving issues on the rear end.
    818 chassis #181 powered by a '93 VW VR6 GT3582R ~400whp/wtq+
    '05 Scoobie 2.5RS Wagon
    '12 KTM RC8R
    '04 Kawa ZZR600, slightly upgraded
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    You are correct Frank, only it's just one driving issue that it causes: bump steer.
    The lower lateral links not being parallel causes toe changes along suspension travel. You can set them very close to parallel using a ruler or a digital angle gauge, but until you test it and adjust it with a bumpsteer gauge, it may have more bumpsteer than ideal.
    Sep 2015
    Hamersville, Ohio
    It is quite impossible to eliminate all bump steer in these cases with the factory suspension setup. 0 is the target but it is unachievable, and besides, some bump steer can be beneficial if it is in the right direction. Toe out at the front under compression would be a good thing if not too much. Toe in at rear under compression is also desirable, provided it is not extreme. These two together would produce slight understeer in corners. Not my opinion, its all in the book. Not the FFR book either.
    Apr 2015
    Andover, MA
    Well, I guess I am going to have to experience it first! I am hopeful that the stock suspension set-up is very driveable, but if bump steer is an issue then I will be forced to learn something new to improve it. This 818 build has been very educational so far!
    Bowling Green, KY
    Ben,
    The character of the car improved and became a joy to drive after eliminating much of the bump steer that my R had. I will have to look at my notes but if I recall correctly I was seeing .250+ toe out on each front and at least that on the rear, now I have around .010 out on the front and .007 in on the rear. Bumpsteering the car is not that hard and can be done with a couple a flat plates clamped to the rotor, a floor or bottle jack and a dial indicator on a fixed stand IMO it is well worth the time. The first corner will take the longest, it is down hill from there. Check out Bob's build thread he and Michael used what they had in the shop and transformed the car (I believe that is what he said) Their car was like mine when I go karted, nervous, dirty and uncomfortable.
    I would suggest doing it before installing the body, the job is really not that much harder with the body installed but you just are working in a tighter space.
    Hear is a couple of articles and instructions.
    http://www.hotrod.com/articles/ctrp-...eer-explained/
    http://www.longacreracing.com/instru...0Steer%20Gauge
    http://www.irvansmith.com/scart/arti...articles_id=11
    Hindsight's Avatar
    Atlanta
    I had the same experience. The 818 wasn't even fun to drive before fixing bump steer. It was a real handful and pretty scary, darting to the left and the right over every tiny bump in the road, and the same when applying the brakes. The bump steer fix was the best mod I have made to the car... well maybe it was second to re-routing the exhaust so I wasn't inhaling it while driving.
    What method do you use to adjust the front bump steer? Are you adjusting the rack height through shims/bushings or spacing the tie rod end at the steering arm? If you are adjusting the tie rod end at the steering arm, did you replace the end links with rod ends? Thanks for your insight!
    ~ Mark
    818C S/N 429ES: Start Date 1 September 2016
    2001 NB Miata LS3 V8 440 rwhp
    2004 Miata MazdaSpeed Factory Turbo
    Kirkland, WA
    Quote Originally Posted by fastzrex View Post
    Adjusting the steering arm, you will need to replace the rod ends, adjusters/sleeves and stud/shaft, I have documented the parts that I used in this tread.
    Tony Nadalin
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Hindsight's Avatar
    Atlanta
    You can buy a kit from Baer Brakes. It's like $170 or so. Has everything you need except for a big 5/8" bolt and lock nut that you replace the spindle with. Check Plavan's build thread for instructions on drilling out the spindle. The Baer kit has a rod end for the tie rod. You just use spacer shims and replace the taper bolt with a 5/8" bolt. For my S at 4.5" ride height, the magic number was 46 or 47mm of shims. You can also buy shims online. I have some info in my build thread too.
    Bowling Green, KY
    FFR also has a PDF R supplement that has recommendations for a starting point for R ride height. Looks like Frank, Bob and a few others will have a good starting point of an S.
    Thanks for the info! Are you referencing your build thread for the bump steer components?
    ~ Mark
    we must have gotten really lucky, because we have no bump steer that we can feel. Watch the steering input in our last video test session, I'm sure it will all turn to **** when we lower the car another inch in the front.....
    Tony, thanks for your work in finding these parts and process. I found the following in your build thread and posting again so I can find them in the future and for other's reference:
    Here are the parts I sourced out to get a bump steer kit that would work, height wise and adjustable
    http://www.speedwaymotors.com/Adjust...=91636055PINTO
    http://www.speedwaymotors.com/Search...+Inch+x+1+Inch
    http://www.racecraft.com/index.php?m...result&search_ in_description=0&keyword=RC21083&x=21&y=8
    http://steinjager.com/shop/index.php...earch=J0041201
    ~ Mark
    Could not get the links to work.
    Kirkland, WA
    Quote Originally Posted by frankc5r View Post
    The links in my original post #661 work, http://thefactoryfiveforum.com/showt...attle-WA/page3
    Tony Nadalin
    I've been following this thread with interest. I am curious as it seems that the Whiteline kit noted by Junty from New Zealand has not received much support. I see the Baer system discussed as well as the DIY system which both require some modification. Am I missing something? Seems the Whiteline is a bolt on made for Subaru front end. I'm at go cart stage with my street only 818S, is it more an issue with 818R that need more adjustment than the Whiteline kit allows?
    Kirkland, WA
    I'll be buying the Longacre gauge as well. They have a new one with billet plate and digital gauge. All this "race stuff" though.... for my "street car". Kind of afraid my next move is going to be selling my daily driver and replacing it with a tow vehicle then buying a trailer and, and, and....
    You should look at the Longacre refurbished list as all the stuff on this list has just been used at shows, and it can save you lots on $$$$. I live somewhat close to Longacre as they do most of their testing at the Monroe circle track about a mile away from them so they have some great products that actually work.
    Tony Nadalin
    Kirkland, WA
    Quote Originally Posted by tgf05354 View Post
    The whiteline does not solve the bump steer issue on the 818 which is different geometry than the WRX. You can use the DIY system w/o modification, as for racing I wanted to make sure I had matched the taper 100%. The good thing about the DIY is that no stock part is modified so if you break something at the track I don't have to then find someone to bore the spindle out for the strut.
    Tony Nadalin
    Bowling Green, KY
    Remember ride height and control arm location also come into play and what you find on an S will differ from what we/I have found on the R. Personally I have not worked on or checked the bump steer on an S. I enjoy playing with this kind of stuff and more than willing to work with 818 owners that are close to Bowling Green KY.
    Yep, I screwed up, copied the text rather than the actual underlying link address; and then did not test. I will do better next time!
    ~ Mark
