Results 1 to 10 of 10
Thread: Sitting on the dyno
    Senior Member Roger Reid's Avatar
    Caldwell (near Boise) Idaho
    Sitting on the dyno
    Well, the "Hammer" had some low speed idle hunting issues. So I took it to "Throttle Works" in Boise. They have some knowledgeable people there who know the E-38 ecu pretty well. My goal was and is drivability. They use a Mustang dyno which usually reads lower numbers than, for example, a Dyno Jet. No numbers yet as I will enplane below.
    I don't have final numbers yet as there are some issues. The engine is an LS7 from Schwartz. What I found was...
    First, the fuel air ratios near idle were up and down near idle. That caused the "hunting and surging" I was experiencing. That has been corrected and now drives well.
    Second, while under full load we had some knock. So he backed off the timing from 29 to 27. Still had some knock so he went to the knock tables and found they were zeroed out. Translation, no knock control. Perhaps Schwartz designed this tune as a race engine only which could justify zeroes in the tables. Now there is a question "are there any knock sensors below the manifold"? Now I get to take the manifold off to find out.
    So if there are any other Schwartz LS7's out there, check your ECU tunes.
    There a few more "to do" items before bringing it back for another dyno run. I'll post numbers when I get them.
    Jan 2015
    Southern Illinois
    I would advise anyone not to hesitate to have an independent check if they have anything but a factory ECM and tune. Mine was supposedly tuned by a reputable shop. They had the high and low octane tables switched! Also the wrong MAP sensor and several other anomalies. It ran, but not right. The checking was done with EFI Live which I believe has the E-38 pretty well sorted out. I question if some of the other tuning software has bugs in it but that is just a guess.
    Ken
    I know on other LS engines, the knock sensors are external and mounted about right in the center of the block on both sides....right behind the aluminum engine mount brackets. So the LS7 has them located internally?
    Shane Vacek
    www.vraptorspeedworks.com
    Shane, I think you are right. I will put her on the lift and check just to make sure the knock sensors are on the sides.
    Senior Member Kempo's Avatar
    Cabo Rojo,PR. USA
    You have one nice looking GTM!!!! The older LS engines LS1 and LS6 have their Knock sensors under the intake manifold. LS7s have them on the sides of the block.
    GenII GTM #354
    Delivered (02/09/11)
    Senior Member The Stig's Avatar
    Charlotte, NC
    Kempo.
    It's good to see that you're still here from time to time!
    The Stig
    GTM #0081
    Quote Originally Posted by Kempo View Post
    I put her back on the lift. Yup, the knock sensors are on the side of the block. Now I just need to find a copy of the ECM knock sensor tables for an LS7.
    Cabo Rojo,PR. USA
    Quote Originally Posted by The Stig View Post
    Kempo.
    Hey Mike, I do drop by from time to time to see how the builds are going. Glad to see yours is coming along nicely.
    GenII GTM #354
    One of my to do list before putting her back on the dyno was to wrap the exhaust under the air intake. The headers were wrapped before the engine installation. It seems that while sitting still either on the dyno or at a stoplight, the air intake temperatures were spiking because of the close proximity to the exhaust.
    Houston TX
    Quote Originally Posted by Roger Reid View Post
    You may want to consider making a shield and potentially coating that shield.
    I made some up and sent them of to jethot to help manage heat.
    GTM # 294 Build Start Date 10/12/2009,
    2000 C5 Donor, LS-1 Twin Turbo, AC/Heat, G50-20.02 6 speed, Brandwood Cable shifter
    Build site. http://s679.photobucket.com/albums/vv153/dfraser/
