Results 1 to 10 of 10
Thread: Reverse switch G50/03
    Oct 2014
    Southern Pines, NC
    So I know one of these plugs is the reverse switch for the transaxle but which one? And what's the other one? It's about time to wire up the reverse camera and pre wire the reverse lights..... Didn't get what I wanted on the Google search and I thumbed through the manual but didn't see any mention of it, but I could've missed it. Thanks for the help!
    Houston TX
    Quote Originally Posted by tucker298 View Post
    On mine its this one
    GTM # 294 Build Start Date 10/12/2009,
    2000 C5 Donor, LS-1 Twin Turbo, AC/Heat, G50-20.02 6 speed, Brandwood Cable shifter
    Build site. http://s679.photobucket.com/albums/vv153/dfraser/
    Banned
    yep that is the plug you are looking for.
    Erik Johnson
    (720) 899-6005 phone
    Hello Tucker,
    could you be so kind and measure the horizontal distance (looking from the top of the transaxle) between the center of the X frame and the axis of the transaxle, see picture attached:
    I'm building a CAD model of the GTM frame for my build and i need to know where the transaxle falls relative to the frame.
    thanks a lot in advance for your help,
    Oct 2014
    Southern Pines, NC
    Sure thing! Ill get those numbers to you tomorrow
    Oct 2014
    Southern Pines, NC
    Sorry for the delay, hope this pic helps! If you need more measurements just let me know.
    Hi,
    sorry, my initial picture was not all that clear.
    I add 2 drawings below, one viewed from the top, another viewed from the right side. In both we see measurement A that I need. I also added measurement B.
    It's better if you give me the measure, because it's difficult to judge with one picture.
    sorry for the trouble, but these are critical for my project, and the nearest GTM is 9 hours drive from where i live
    thanks again
    Oct 2014
    Southern Pines, NC
    Great pics! That's very informative! I'll get you those measurements tonight hopefully
    Oct 2014
    Southern Pines, NC
    Measurement A is 5.5 inches and B is 8 inches
    thanks a lot !
