Thread: Connecticut registration and emmision testing.
Hybrid View
    East Hartford, Ct.
    Has anybody gone through the Connecticut registration process with their replica? It clearly states that a composite car must go through an emissions test after inspection and before registration. I have also "Heard" that a "Replica" of an earlier car like a 1965 Cobra could be registered as a 1965 Cobra and not have to go through emission testing even though the car may have a modern engine. I have also heard no matter what your car replicates, the car has to be tested based on the engine.
    I am in fear of the Ct DMV and couldn't possibly go there and ask those moronic robots as I am too easily riled.
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Start here: http://www.bipac.net/page.asp?conten...olbox&g=SEMAGA Pull up your States file and read it well. Lots of good info.
    This info states that composite cars are exempt from emissions testing...page-2, second bullet point.
    Ray
    East Hartford, Ct.
    Thanks Ray, but read the paragraph at the bottom of that page.
    Junior Member Rich Drake's Avatar
    It can be registered as the make and year of the replicated car. Emissions testing is not required, but you will need to have emissions controls applicable to the year of the engine.
    East Hartford, Ct.
    I understand now. Thanks Guys. Looks like I'll have my work cut out for me as I stripped all that stuff off for off road use.
    I was wondering how the CT dmv would handle a blue print engine transmission combo, how they might determine the model year of engine, if antone knows?????
    Doug
