0
0
Engine cover for "R" - roll bar channel?
I'm making an "R" rollbar for my "S" and I know I need to cut a channel in the engine cover for the rear brace of the roll bar to go through. What I'm confused about is that the pics on FFR's website of the R show a carbon fiber cover on the channel. But it's riveted in place. Is that really to say the engine cover on the R is not removable without drilling all the rivets out?? If you don't have that carbon fiber cover, how do does the engine cover get support, since the humps won't be attached to the side of the side sail. I guess just the hump block-off plates?
Thanks Bob, very helpful. I will do the same with the center hood pin... though maybe use a hood latch. How high is the top of your roll bar from the top of the frame? My new one is about 18" vs the "S" model which was 13".
Originally Posted by
Hindsight
I'm about the same. 18" to center of top cross bar.
Engine cover LS 2.JPGengine cover LS.JPGrear deck install 1.JPGrear deck install.JPG
I cut the side sail at the roll bar just behind the brace and bolted it in place so it is fixed but removable. Like bob I have quick release fastener between the humps at the front of the engine cover and side sail and engine cover.
Mitch Wright
If I had a do over, I would use Mitch's method, except I wouldn't have a gap between the 3 panels.
Any of you 818c conversion guys want to get rid of the engine hump panel.
Great idea Mitch! Does that work with the hinges, do you know? Looks like himps might hit the rear brace?
I am thinking about welding my rear support bar slightly outside of where FFR welds theirs. They put it on a gusset but I was going to put mine directly centered over the 2" square tube where it ends at the cross frame brace. This would make the rear brace go straight back instead of back and inward which may reduce how much engine cover I have to cut. Any opinions on that, from a strength standpoint? Seems ok to me....
Yes I believe my cover would work just fine with hinges.
I do have a template made for a filler plate for the opening between the side sails and the main engine cover that will be part of the side sail and not interfere engine cover removal. That is at the beginning of things to do once the car spends some time on track.
Will have to look at my chassis to have an opinion on rear brace attachment points.
- You may not post replies
- You may not edit your posts
Forum Rules
