Fuel System Questions
I will be using a 289 with a carburetor and mechanical fuel pump in my FIA build. I didn't think that I needed to run a return line, is this a valid assumption? Also, I installed the kit supplied fuel pickup in the tank, but this is designed for a fuel injected setup correct? Do I need to switch over to something else, or can I just use the existing pickup and cap the return?
FFR #8833 289 FIA 3-link
http://thefactoryfiveforum.com/showt...FIA-build-8833
