Hi everyone, with 3300 miles on my build the FFR roadster seats where looking very tired. Lifted the seat up and the adhesive between the foam and the vinyl completely failed. The vinyl was pulling away from the bottom and the seat looked worn out. It looked worse than the attached photo. Stopped by a local auto upholster and he suggested to put a thin piece of plywood under the foam, you could staple the back and sides to the plywood and it will give you a much better "feel" to the seat. The plywood is 15/32, I would not go any thicker, you just don't have much material to stretch over the wood and keep the original shape. Auger bit to make a hole for the bolts that hold the seat to the frame. Staple gun around the three sides, lots of staples. I was going to use an adhesive along with the staples but did not. May regret that but can always redo later. The seat does "feel" better, really stiffens the foam and raises up the body a bit. You would think that 15/32 would not make that much difference but as soon as I got in to try it out noticed it immediately.
