Results 1 to 40 of 48
Thread: Coyote Vs other options.
    Senior Member Misterfubar's Avatar
    Olathe, KS
    I'm sure this has been discussed plenty, and I've read quite a few posts on the topic but I'm looking for some fresh opinions. I'll be ordering my kit soon(maybe) and I need to be talked into(or out of) going withe a Coyote. My original plan and budget I had decided that IRS would be a better use of the price difference between using a 5.0 SBF vs a Coyote, but the more I look for engine and evaluate my budget I think I can still go with a Coyote. Used low mileage motors are a little cheaper and more plentiful than I had originally thought.
    Basically I'm looking for a Pro/Cons list to help me decide.
    I will be going with IRS either way as I've already got the donor parts I need out a low mile '15.
    The wife wants power steering, so either motor choice I'll end up with that.
    I may end up going with AC and have already looked into kits, just not sure if they'll fit with a Coyote. I know it's silly, but I found myself more likely to put the top down on hot days because I could blast the AC on my last 'vert so I'll also be more likely to drive the FF on hot days if I have AC. Call me spoiled.
    Fuel injection is a must. As much as I'd love to pop the hood and see the big ol' oval Cobra air cleaner, it's 2016 and I just can't bring myself to put a carburetor on anything. I guess I could always go with any of the FI systems designed to replace a carb so my big air cleaner isn't totally off the table.
    The car will likely end up seeing an occasional 1/4 mile and I might even get back into some SCCA stuff if I can find the time but that will never be the primary use of the car.
    Thanks in advance for any helpful tips you take the time to type up for me.
    Senior Member ram_g's Avatar
    Houston, TX
    Some necessary background before one can formulate an intelligent response:
    - Where do you live? Seasonality? Elevation and elevation change?
    - What do you want to use the car for? Daily driver? Groceries? Weekend cruising? Car shows?
    FFR Mk3.1 #6720. Carb'd 302. Fun.
    Olathe, KS
    Quote Originally Posted by ram_g View Post
    Kansas city area. Elevation is 1000 feet +/- 150. Hot(ish)/humid summers. Potential for nasty cold winters. It'll be a 3 season car, It won't come out much in the winter time.
    Car will be used as a weekend cruiser, with occasional spots of daily driver use and maybe a bit of track time once or twice a year. Car shows aren't likely to happen often.
    I've done two SBF builds and getting close to wrapping up a Coyote build. I can't give a full driving report on the Coyote yet. Only first impressions. A relatively simple 5.0 SBF build will be a solid runner and less money than the Coyote. But 100 HP or more down from the Coyote. A 5.0 SBF with enough performance mods and parts to approach the power output of the Coyote will easily be similar in cost. Can even be more. When compared apples to applies, that's where the real value of the Coyote shows through IMO. I don't consider the older tech 5.0 EFI or even any of the newer aftermarket EFI systems to be in the same league as the fully engineered OE Coyote design with all the bells and whistles like VVT, port EFI, 4 valves per cylinder, coil on plug, and the list goes on. The Coyote starts instantly and runs beautifully. I can't wait to do something more than putt around my neighborhood. The Coyote is big, but it does fit and with the recent changes doesn't give anything away in footspace. It loves to rev and makes great torque starting at fairly low RPM. It doesn't look or sound particularly authentic or old school. For some this is a deal breaker. But if that's not your concern, it's a hard option to rule out if you really compare them evenly.
    Houston, TX
    Quote Originally Posted by Misterfubar View Post
    First statement suggests either a carb'd SBF or a Coyote to me, second statement leans more towards a Coyote. Basis that, sounds like either will work fine for you with a slight edge to the Coyote.
    BTW I don't get the statement "it's 2016 so it must be FI". Why? I (and plenty of others) am perfectly content with my nicely running carb'd 302. Starts every time, idles fine, runs fine, probably uses more gas than a FI engine but since it's not my DD, so what...
    Have You Considered An LS Or Maybe A SBC?
    Ponder for a while as to what you really want, then be very honest with yourself about your mechanical and fabrication abilities before you pull the trigger.
    If you make your drivetrain decision based on facts, knowing what your abilities both technical and financial are, then your build will go well.
    Make sure that if you do something that is not supported by Factory Five that you are able to pull it off with minimal support.
    Just Do Your Homework First & Read, Read, Read The Manual Before You Order Your Kit!
    Good Luck From The Dark Side!
    I have a 2012 crate Coyote in my MkIV. Here's my list of PROS after 30,000 kilometres. I tour in mine (last trip was 3750 k to London Ohio where I rodded the crap out of it), show it, Sunday drive it and take it to the grocery store every chance I get.
    PROS
    - comparing HP with pushrods engines (carb or EFI) the cost of the Coyote installed will run about the same if not cheaper.
    - expect 450-500hp with no mechanical mods and a slight tweak to the tune.
    - super strong 6 bolt mains bottom end. It'll take the power all day.
    - nice smooth power at lower rpm makes it very easy to putt around the streets. Builds crazy power from 3500 revs to redline at 7,000. Better hold on tight and have the wheels pointed where you want to go.
    - great fuel mileage on long cruises. Runs great on 87 pump gas. No need for those 93/94 pumps at the Chevron.
    - runs just as good at sea level as it does at 4,000 feet.
    - it is as close to plug and play as you're going to get. Install - wire - plumb - fire it up and it purrs at 900 revs right out of the cardboard box.
    - FFR have engineered an install kit. The engine install and wiring are relatively easy. It fits /fills the engine bay. Coyotes are just as wide as FEs.
    - 2 year warranty from Ford Racing.
    - if you run into an issue you can't resolve, the Coyote is the stock engine in the GT Mustang. Go to your local Ford dealer for help.
    - built in Canada eh.
    CONS
    - hmmmmm? ahhhhh? Need I say more?
    Olathe, KS
    Personal preference really. I like technology so I don't think I could be content with a carb'd smallblock. The last vehicle with a Carburetor I had was an International Scout and I converted it to FI.
    You just confirmed a lot of the reasons I had rattling around in my head to go with a Coyote. I'm not a muscle car guy(The Shelby Cobra being one of the few exceptions for me), so what it looks like under the hood, and the sound isn't that important to me. Don't get me wrong though, I want it to sound good when I mash the go pedal, but I can do without the lobey obnoxious idle. The biggest concern I had with going with a Coyote was the budget, and really that isn't that much of a concern for me not that I've looked into it a bit more. I'm not going to go all out and buy a brand new one from Ford, but a lower mileage take out of a newer Mustang and all the associated costs of getting it to run outside of it's original home are within my planned budget. The technology loving guy in me says going with the Coyote is a no-brainer, but the doesn't like to spend money guy in me was hesitant. Really glad to hear about the not losing footspace. Most of the builds I'd stumbled across were older ones and that was a concern.
    Hell, I'd love to do an Ecoboost or a Toyota UR motor but I understand my limitations and while I'm perfectly capable of working on or troubleshooting just about any newer motor, my fabrication skills are a bit lacking. I'll be sticking to the usual Ford choices.
    Olathe, KS
    Quote Originally Posted by Dave Howard View Post
    PROS
    CONS
    Thanks. More confirmation. Is 30,000 kilometres a lot? I'm a dumb American and we're too stubborn to adopt a better system.
    Raleigh NC, OIB NC
    All of the above speaking from only 4000 miles. If you need a rump rump 427 solid lifter idle for your aural pleasure, program it into the tune. Doing an olden day thing like getting up on the cam is just a push of the pedal away. Put it in a higher gear put down the pedal feel & hear the surge around 3300/3500RPM. In a lower gear its to quick to feel & to loud to hear the change.
    4 season Daily Driver, registered for 1st auto cross, will do VIR track days & 1/4 mile runs. With 315 drag radials bring the revs up a bit quick off the clutch & the car just leaves. A light chirp & the 1 - 2 shift is coming up fast. Flexing neck muscles is a good plan.
    CONS, finding new excuses to go to the store.
    Wrong visuals if you are a purest.
    Kevin
    MKIV #8234
    30,000k is 18,000 miles. Here's another one for ya. Gas mileage at 120 kph (72 mph) was 22 mpg(imperial). Simply, with the FFR supplied tank I can squeeze 5 hours between fill ups while touring.
    Like Bear, I tried to dress up my Coyote with the BOSS 302 intake, installed the same K&N PVC breathers and ditched as must hose as possible. Hid wires, and plumbed with stainless braide. The only other bling I'd love to throw on would be a Whipple 2.9 supercharger.
    http://thefactoryfiveforum.com/asset...7&d=1420689839
    If you're going to get a used Coyote, just do your homework. I assume you know it's nearly impossible to make it run with the PCM out of the donor vehicle. The conservative option is to use the Ford crate motor controls pack that has everything necessary to make a manual shift Coyote motor go. Just be aware, if you aren't already, that there are two different versions of the Coyote. 2011-2014 is the first version. 2015-2017 is now an updated version. The older version is no longer sold as a crate motor, but I'm assuming the older version controls pack is still available. The current crate motor is the 2015-2017 version and uses a newly designed controls pack. Completely different harness, PCM, PDB, etc. The two versions are not compatible. You have to match the right controls pack with the right version of the Coyote. Just a heads up if you didn't know this already. There are aftermarket PCM options for the Coyote, but I personally know nothing about them and have seen just enough on the various forums to know that's above my pay grade. Good luck whatever you decide.
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    I went SBF and the only reasons for me was old school look and simplicity. The Coyote is a great engine and you can't go wrong with but for me personally, it doesn't look right. Same as a LS but it is your car and it sounds to me that there is no reason for you not to go Coyote.
    Kyle
    Senior Member Duke's Avatar
    Taxachusetts
    It's cheaper to do it once and do it right then having to redo it or venture into a second build.
    I'm not smart enough to make a heavy car fast, so for me it is all about the weight.
    On a roll Al_C's Avatar
    Wheaton, IL
    When I was evaluating options, I asked a lot of people for their input. One of them was Tony at FFR. I said " Tony, I'm debating between a small block and a Coyote." He barely let me finish. "Go with the Coyote", he said. "You won't be disappointed." My engine is still sitting on a pallet; each step I take is a new adventure. Nevertheless, I have no regrets about my engine choice. I can't wait to get it installed and running. (I just need more time to work on the car!) Look at it this way: if you don't choose the Coyote path, you'll always wonder "what if..."
    Chino Valley, Arizona
    That's the beauty of these cars - you can build to what's near and dear to your heart. My wife wanted the Ford crate 427 and I debated between that and the Coyote. In the end, I wanted to build an EFI pushrod 5.0 with every go fast part I drooled over for years from the old 5.0 magazines - as I built up Fox body Mustangs. My next build will use a Coyote...really learning a lot (from guys like EdwardB) and I'm finding Ford's newer big mod motor looking good...if only Ford releases the Voodoo motor as a crate option...
    Raleigh NC, OIB NC
    Coming slowly. Loaded Heads less cams are available for $5000MSRP a pair. A bit pricy when you can get a 435 Coyote for a bit more.
    Almost there crate engine was shown at SEMA. Coyote 5.0 bottom end Voodoo top end. 500+HP. Forgot price.
    Kevin
    MKIV #8234
    Jax Beach, FL
    There is nothing wrong with a Coyote. There is nothing wrong with fuel injection. The Coyote is space challenged in the engine bay. It all works, but not fun to work on.
    Just in case this is your reasoning: Don't think for a second that you don't need to tune EFI. Also, more of these cars have gone home on a flat bed due to EFI issues than carb issues.
    The A/C that you can put in these cars is probably not going to give you the volume of air that you are thinking of. If you don't have a top on it, I don't think you will accomplish much. Also, as MikeinAtlanta said, you a packing on weight. One of the things that makes a Cobra what it is, is light weight. They are really a sports car, meant to go around turns. They are not really a muscle car. They get called that because they are American.
    "It's 2016......." Not necessarily saying this is you. But, I do question when people really want a modern car and build a Cobra. It is not modern, and you can't really make it that way. My friend has a Coyote, supercharger, IRS, ABS, traction control, keyless start, ipad for a dashboard, high back seats, and it is still hot, loud, rough, and nasty. Make sure that this is what you REALLY want. Also, if you dream of cruising around with your wife, make sure that she understands what these cars are. My wife has about a 60 mile range, and would have a much better time in a 911. You don't want to be one of those guys that has a Cobra for 5 years and has 300 miles on it.
    Or the 5.0 Coyote with stack injection
    http://st.hotrod.com/uploads/sites/2...-50-coyote.jpg
    Olathe, KS
    I was aware of all of this, but I'm glad you posted it here for anyone else that might be reading. I've seen or heard of a few success stories using the donor PCM, but I'll be hitting the easy button and going with the Ford control pack for whatever version motor I end up with.
    Olathe, KS
    Quote Originally Posted by Duke View Post
    I've definitely decided to go the Coyote route. It may mean I miss out on the current sale, but I'm ok with waiting a bit longer to build what I really want. The biggest reason I was considering going the SBF route was my hobby budget could afford it a bit sooner.
    Olathe, KS
    Quote Originally Posted by 2FAST4U View Post
    Those are pretty, but I'm not even sure I could afford to look at the cost.
    Olathe, KS
    That is beautiful to me so I guess I don't fall into the purest category.
    Olathe, KS
    I appreciate the honest advice. I can see where my posts would lead you to think I'm wanting to build a modern car that just looks like a Cobra, but I don't. I want the loud, rough and nasty, but if I can have all that with just a slight bit more comfort I'm going to.
    The LS-3 can be mounted to the existing Factory Five mounts so fabrication is minimal.
    That platform is lighter, creates more power and has a smaller footprint than the Coyote.
    PACE Performance has all sorts of LS configurations and they are reasonably priced.
    Can't Hurt To Look!
    GoDadGo = GoChevGo
    Quote Originally Posted by cgundermann View Post
    GoDadGo = GoChevGo
    If my car wasn't such a budget build an LS would have been sitting between the frame rails instead of a 383 SBC.
    Those Engines Are Insane!
    Jax Beach, FL
    Well, Sir, you have come to the right place!
    May 2013
    Slidell la
    I built an Fe, I went old school. But the coyote sounds like a fun engine
    Mk4 # 8834 delivered 03/20/16 2015 IRS wildwood brake upgrade, 18"x9" front 18"X11" rear halibrand wheels, 390 FE, tko600
    May 2016
    North of sacramento Ca.
    I went with coyote and t56 mag in the 33. That way i got done with budget real fast and on to other parts wanted and needed !
    I too like the pic from Bear. That is exactly what I want in my cobra when I get it. Hopefully pretty soon!!
    Agreed GoDadGo - just watched "How It's Made Dream Cars; Ultima" and they had some nasty LS options...one over 1000 HP...
    The LS-3 with the front drive distributor and carb set up really could give a Ford Look if you found some generic valve covers.
    At 550 HP, that's a dog walker for sure since it's an all aluminum mill!
    Just make sure to install the battery up front to weight things down a bit.
    http://paceperformance.com/i-23842416
    2bking's Avatar
    Garland, Texas
    The LS-3 is a 6.2L engine and weights a bit more than the Coyote (466 lbs vs 444 lbs). In factory trim it is advertised at 430 hp at 5900 RPM. Since it is a larger displacement it is not exactly apples to apples comparison to the Coyote. There are other Ford engines that can deliver similar performance to the LS-3 and keep your roadster in the Ford family.
    King
    Just not a fan of the Coyote Motor because it leaves no room under the hood, so that's why suggested the LS Option with the Front Drive Distributot because they are different.
    At Camp GoDadGo, the 383-SBC with ZF-Trans was the only way that I could have the 3-Link Rear and a 6-Speed Transmission so off the grid I went.
    Since my daily driver has 6 gears, and I use them all to the best of my ability, my MK-4 wouldn't have made me happy with only 5.
    My goal was to show OTHER OPTIONS as the string requested.
    May 2013
    Slidell la
    Godadgo, wanna come over and take a ride around the block in the Fe powered go cart?
    Quote Originally Posted by Hottrodder427 View Post
    Heck Yes!
    When?
    Tomorrow Or Tonight?
    Olathe, KS
    So what's a good transmission to use behind a Coyote? I see that the Getrag MT82 that will be behind just about any used motor I find will need a custom driveshaft and a little bit of work to install the shifter. Is there another good option that won't murder my budget?
