Thread: 33 Hot Rod head lights
    Jun 2014
    Has anyone out there mounted the headlights on the fenders of a full fender Hot Rod. If you did, how did you do it?
    Thanks for the help, Larry
    May 2016
    North of sacramento Ca.
    Have not mounted them, but am going to mount stock 33 headlights with stock mounts, will post in build thread. They are big and i will probably use some kind of reinforcement under fender. If you look at Cardifkid #24 on FFCars.com he built some nice fender braces.
    Jun 2014
    Quote Originally Posted by 1932 View Post
    Thank you 1932, I will check it out.
    Aliso Viejo, CA
    Talk to Dan Ruth aka kgb911. He'll help out.
    May 2016
    Yes Dan is very good.
