Results 1 to 11 of 11
Thread: Your solution of Front Tow Hook
    Since it's almost impossible to tow the 818 from the front especially with a splitter, I need to install a tow hook.
    There are lots and lots and lots of them on ebay. Either straps or hooks. The only problem is they have a 15-16mm bolt and that's just too big for our front nose radiator frame tube!
    http://www.ebay.com/itm/Universal-Eu...5FD-rIoQvBslqg
    I have the new nose. If I weld a metal piece on the rad frame in the middle of the rad opening, it will required to cut a half moon in the nose insert cuz the fiberglass goes a bit over the tube.
    If I weld it under the tube, it will cause problem to remove the floor aluminum.
    I could bolt a tab underneath the rad tube in the middle, using a smaller bolt, then unbolt the tab to remove the floor. Could possibly work well.
    What did you guys chose as a solution?
    Sep 2015
    Hamersville, Ohio
    Frank, I've been studying the situation too. I can't really imagine pulling on anything forward of the front suspension points. The rear does ave some promise tho. Pull it backwards if it comes down to that.
    Senior Member Junty's Avatar
    Dec 2013
    New Zealand
    I created one my making a bar/rod that extends above splitter - below radiator, back to main chassis frame in front of battery. I then added a hook to the outside of front fibreglass. I also added a similar one to rear (although) much shorter - also above rear diffuser and this connects to centre of rear chassis frame - trans/rear mount area. Both these are more than strong enough to pull an 818 from the gravel traps - thankfully I haven't needed to test this yet - touch wood!
    Not exactly the same, but this may inspire a solution. Had the same issue on the cobra and fabricated a mount from DOM and a nut, then used a Miata hook available at any salvage yard for almost nothing.
    Reno, NV
    I plan on attaching a tow ring to the roll cage. Like the way Davidson Racing did on their Eagle. It's sticking up through the roof.
    818R Build date 10/31/15
    Edmonton, Alberta
    I was thinking something similar out of the hood near the windshield.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    Frankfort, IL
    I was actually considering this method as well. It is what FFR has for the Challenge Series cars.
    http://www.factoryfiveparts.com/chal...ries-tow-hook/
    A lot more solutions than I thought. It's inspiring.
    For those that would pull the car from the rear, if on a tow truck like that wouldn't the wind hit inside the windshield and swirl around in the cockpit and pushing down on the dash? Just asking, that's the reason why I prefer a front hook but if airflow backwards on the windshield isn't an issue then I guess it's easier to have the hook at the rear.
    Not convinced yet on making a hole in my hood.
    Edmonton, Alberta
    A rear hook would be helpful at the track when you run out of talent.
    818 SRX - #91
    Arrived 01/02/2014
    I installed a both a front hook and rear hook. The front was a super large hook i bolted through the frame (not the radiator section) and can easily hook a ratchet strap to it and use it when strapping the car down in the trailer. The rear is bolted through the frame and is a European style thread in hook like on BMW or Audi and just flops around. I think the rear one adds some style to car and can see it in my thread. Here is the pick of the front one . It was taken with my phone and tried to capture it as best i could. I use both every time load the car in the trailer and works well.
    Yeah that's a place I can't do it. I've got the front race splitter, quite longer, so I blocked off the lower opening on the nose insert.
