Since it's almost impossible to tow the 818 from the front especially with a splitter, I need to install a tow hook.
There are lots and lots and lots of them on ebay. Either straps or hooks. The only problem is they have a 15-16mm bolt and that's just too big for our front nose radiator frame tube!
http://www.ebay.com/itm/Universal-Eu...5FD-rIoQvBslqg
I have the new nose. If I weld a metal piece on the rad frame in the middle of the rad opening, it will required to cut a half moon in the nose insert cuz the fiberglass goes a bit over the tube.
If I weld it under the tube, it will cause problem to remove the floor aluminum.
I could bolt a tab underneath the rad tube in the middle, using a smaller bolt, then unbolt the tab to remove the floor. Could possibly work well.
What did you guys chose as a solution?
