Setting Ride height?
Ok, how is it we set the ride heights on these beasts after the front end is complete. I have the silver bodied shocks which have to be installed body down so the adjuster is at the bottom. I can get to one of the set screws on one shock but have been unable to turn the ring to adjust the darn things. I need to raise one side about 1/2" to get it level. It looks like I would have to completely remove the grill assembly and possibly tear the control arms out. help!!
I can't help you with the access. But you do have the suspension unloaded, right? With it hanging loose, they're not hard to turn. Also be very careful with those set screws. It's real easy to mess up the threads and that makes them hard to turn as well. Many take them out. Once under load from the springs, the adjuster isn't going to turn.
Also, for the record, unless you have it on scales, best practice is to turn the front and rear pairs at the same time and the exact same amount. Not one at a time.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
