Results 1 to 40 of 64
Thread: Valin's Roadster Build Thread in Pictures # 8632
    Valin's Custom Cars valin's Avatar
    Jan 2015
    Sudbury, Ontario
    This thread is a bit late on this site, as my car is now finished, but I thought I would post it up in case anyone is interested in it, since you don't see them built with BBC power. I have about 900 miles on it now, and absolutely love it!
    Build specs:
    MKIV Roadster #8632
    Powder coated chassis
    3 Link rear suspension
    Manual steering rack
    Body cutouts
    Wind Wings
    Sun Visors
    Cup holders
    Hood Hinges
    Side Louvers
    Heater
    Wipers
    Chrome Roll Bar
    Brake duct wire mesh
    Electrical system completion components
    Stainless side pipes
    Leather seat upgrade
    Wilwood big brake kit with red calipers
    Roll bar grommets
    Leather steering wheel
    Koni coilovers
    Wilwood pedal box with matching 3/4" master cylinder for the clutch
    Individual billet brake and clutch reservoirs (3)
    Autometer 5" speedo and tach with shift lite
    Autometer 2 5/16 oil pressure, temp, water temp, volt, and gas guages
    Battery cut off switch
    Russ Thompson signal system
    Russ Thompson gas pedal
    FFmetal Battery Box with Optima red top
    Custom built 25 gallon fuel cell with Holley Hydramat
    17x9 Halibrands up front, wrapped in Kuhmo XS 245/45r17
    17x10.5 Halibrands in the back, wrapped in Kuhmo XS 315/35r17
    Motor:
    Chevrolet 454 marine block, all forged internals
    10.5:1 compression ratio
    088 cylinder heads, mildly ported, big valves
    Victor Jr. intake
    Comp Cams 310B camshaft (0.638/0.631 lift, 270/276 duration @ .050", 108 LSA)
    Comp Cams aluminum roller rockers
    PRW High flow water pump
    CVR Protorque mini starter
    Quick Fuel Q-series 950cfm carburetor
    MSD Ignition (6AL, pro billet distributor, blaster SS coil)
    Billet Specialties pullies and mounts
    Canton 7qt oil pan
    Billet fabricated valve covers
    The motor should make 570hp, and 6500 rpm, and 520 ft. lbs. Should be nice and scary!
    Driveline:
    Tremec TKO 600, .82 5th gear
    Mid shift kit from Mike Forte
    Quicktime 6022 bellhousing
    McLeod RST Twin Disk clutch
    McLeod flywheel
    McLeod throwout bearing
    Lakewood clutch fork
    8.8" rear end , 31 spline, 3.27 gears
    Jan 2015
    Sudbury, Ontario
    12v winch installed on ceiling for the body and buck...
    Congrats! sounds like it will be a cool build, enjoy!
    Valin,
    1. Greeting Sir Valin From The Other Dark Side Guy!
    2. Thank God Another Chevy Cobra Exists!
    3. Rat Motors Rule Supreme In My Book!
    Jan 2015
    Sudbury, Ontario
    Valin,
    Hey! I don't think there are very many of us! I really like the ones that are different and unique.
    How far forward did you have to place the engine?
    Also, did you need to change the spring rates up front.
    Jan 2015
    Sudbury, Ontario
    Jan 2015
    Sudbury, Ontario
    Jan 2015
    Sudbury, Ontario
    Jan 2015
    Sudbury, Ontario
    The motor mounts on the BBC don't quite line up.....
    You can see the valve cover is pushing in the drivers side footbox. It will need a bit of modification to squeeze the big block in there to allow clearance for the headers.
    Ended up notching the footbox to fit the engine.
    Jan 2015
    Sudbury, Ontario
    Brake Lines run.
    Rear.
    Finished the notch in the footbox.
    FFMetal battery box installed.
    Jan 2015
    Sudbury, Ontario
    Battery Disconnect switch
    McLeod Racing RST twin disk clutch. It's Puuuurdy. Too bad you can't see it when installed
    Starter gear does not line up with flywheel.
    Parking Brake installed.
    Need to recess this area on the mill.
    Jan 2015
    Sudbury, Ontario
    Cut down the FFR supplied shifter lever.
    Installed Bellhousing and Mike Forte slave clutch cylinder setup.
    Motor mounts extended forward.
    Modified the passenger footbox to clear the headers.
    Had to re-modify the drivers side footbox. After installing the engine (which fit beautifully inside the notch in the footbox), I realized I could not remove the valve covers, so I continued the notch all the way up.
    Engine in for the last time!
    Jan 2015
    Sudbury, Ontario
    Installed the 3 core rad.
    Brake and clutch reservoirs installed.
    Looking good!
    Dash upholstered.
    Jan 2015
    Sudbury, Ontario
    I modified a set of Ford 460 headers to fit. It wasn't easy.
    Body and side pipes on!
    Gauges lit up! I bought all red LED bulbs from Autometer.....brighter than the traditional bulbs.
    Here's a video of the first startup!
    Not going to be much clearance for an air cleaner...
    Jan 2015
    Sudbury, Ontario
    Body work time!
    Primed!
    And Paint!
    And so the painting begins......
    Sprayed down some Super Jet Black fist.
    Taped off the centerline.
    Jan 2015
    Sudbury, Ontario
    Sprayed the Steel Grey Metallic for the stripes.
    Taped off the outside of the stripes.
    Sprayed the Viper Red for the pinstripes after taping a 1/4" strip on the edge of the Grey stripes.
    Taped the red pinstripes off, and sprayed the rest of the black.
    Jan 2015
    Sudbury, Ontario
    Custom air cleaner from RJB Performance.
    Jan 2015
    Sudbury, Ontario
    Had to take a photo with the Turbo Busa in the background
    Final Assembly!
    And....the finished product......
    Jan 2015
    Sudbury, Ontario
    Required badass pose
    Jan 2015
    Sudbury, Ontario
    I didn't really have to place the engine any further forward......but the motor mounts on the chevy are further forward on the block, therefore I had to extend the motor mounts on the chassis forward.
    I went with 750 lb springs up front. It is just about right with weight of the BBC on iron heads.
    Just wondering because I had to move things around to fit my transmission.
    ZF 6-speeds aren't long, but they are rather wide and you can't move the shifter.
    Your Car Has Got To Be A Beast!
    Jan 2015
    Sudbury, Ontario
    The BBC is very wide, and tall. I had to have a custom 17.25"x9.5" drop down air cleaner made to get it to breathe, and it's very close to the hood scoop.
    The car is a lot of fun. After putting some miles on it, I have decided that I am going to swap out the cam over the winter. It is pretty choppy at low rpm when navigating slow 90 degree turns, etc. I pretty well have to drop it into first, and it's a little annoying. I am going to swap out the solid mechanical camshaft with a Comp Cams XR292R solid roller camshaft. It will bring the peak power down to 6000 rpm, but bring the torque curve way down, and it will make a ton more torque down low. With the new cam it should bring the power from 570hp/520tq up to 600/600, but a lot more useable. I'm sure it will be a very different car after that. I'm also toying with the idea of swapping to aluminum heads. It's a big cost, but would make another 100hp and 40 ft. lbs., and probably save me about 90 lbs. I'm not yet decided on that.
    Totally Insane!!!
    It pains me to admit it because you have moved to "the Dark Side" to quote GoDadGo, but that is a truly beautiful car! Even the engine looks great. (Man that stings coming out of my mouth!) The engine sounds like it is an amazing one, and the upgrades you are already considering are simply over the top! Congratulations on creating a stunning car. I hope you enjoy it immensely! And thank you for joining GoDadGo. While he is a beloved member of the family, he does take his share of shots! It's good that he has a friend!!
    Ryan-
    Your car looks incredible! Very well done. I love the details, and that engine is insane.
    Your paint choice is great too, it just seems to fit the car. The red accent sets it off nicely as well.
    I am sure you are enjoying the heck out of it. Thanks for taking the time to post your build pictures.
    Jan 2015
    Sudbury, Ontario
    Thanks guys! I absolutely love it. The weather up here is stating to turn cold, and hunting season has begun, so I'm not sure how much more I will be able to enjoy it this year. I hope it's a warm fall!
    Jan 2015
    Sudbury, Ontario
    Sneak Peak. A new motor is going into the Cobra this year to replace the 454. Going to go a little bigger
    598 Cubic Inch BBC from Blueprint Engines. Hydraulic Roller. 358cc heads. 10:1. Should be just about right
    Will be on the dyno soon!
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    What??? You only just finished your build and now a new bigger engine? I remember all the trouble you went through getting your air filter to fit.
    Kyle
    Kearney Nebraska
    Hey, Nice choice of engine! Thanks for choosing Blueprint! I didn't expect to see one of those going in an FFR roadster when I opened up the forum today. =)
    Serial #9158
    Great build. Love the red accent stripes. How long did your build take?
    Jan 2015
    Sudbury, Ontario
    Haha! A perfect combination!
    Tony Zullo brought me over and introduced me to Chris Larson when we were down at the SEMA show in November. I was inquiring about the 540, when he mentioned he was about to design the 598 on the standard height 9.8 block.......and I was sold! I considered having him do a solid roller setup in it, but I think it will make enough power as it is
    It looks like he and I will be working together at the Barrett Jackson show in Scottsdale next week I hope you boys get the motor on the dyno this week. I'm very anxious for power numbers! That way I won't have to harass Chris about it all next week
    Jan 2015
    Sudbury, Ontario
    Thanks! I took my time with it and put it together in about a year. I didn't rush by any means.
    Kearney Nebraska
    Quote Originally Posted by valin View Post
    I was talking to the R&D guys today, and heard they were building that engine for a factory five roadster. So it is getting closer! I would still harass Chris though, If I was you. haha
    Serial #9158
    bobl's Avatar
    Spicewood, Texas
    That should make one wicked ride! I met you at SEMA and we talked big blocks for a while. I'm real curios to hear some specifics on this engine. I've built many big Chevys, but nothing bigger than a 565 on a standard deck block. I assume it's a Dart block and 4.500 inch crank? What length rods?
    Jan 2015
    Sudbury, Ontario
    Quote Originally Posted by bobl View Post
    Hey Bob! Yes, it was nice talking to you! Blueprint uses their own block design, and yes it's a 4.5" stroke. I'm not sure what the length of rods are, but I will ask for you.
    Some specs for you:
    598 Cubic Inches. 4.6" Bore, 4.5" Stroke
    10.0:1 Compression Ratio
    Aluminum Heads, 119cc Combustion Chambers, 358cc Intake runners, 125cc Exhaust runners, 2.3" Intake valves, 1.880" Exhaust valves
    Hydraulic Roller Camshaft: .647 Intake/.647 Exhaust Lift, 258/266 Duration at .050. 112 degree lobe separation.
    My Victor Jr. Intake Manifold off my old motor
    My Quickfuel Q-950 carburetor
    Hi. Great looking build. I've lost track of the progress. My Coyote/MkIV is just down the road now in Espanola. I'll sneak out to the valley this spring with my Alberta plates for a visit. Every time I take it out it's like a car show at the gas station or the DQ. Haha...love it.
    This is one very bad *** build!!
    the red accents are gorgeous, great work!!
    bobl's Avatar
    Spicewood, Texas
    It ought to be monster. The 598 I built for my boat made 800 HP at 6000 rpm using afr 335 heads and a slightly smaller hydraulic roller cam than yours. It did have a Dart tunnel ram with 4 2bbl efi throttle bodies that I made. And it would run wide open for hours on end. I would certainly expect your engine to make similar numbers. Not sure what effects the rod ratio will have on it though. They are going to dyno it for you, right?
    Some specs for you:
