Another question for the more experienced.
Trying to remove the lower links from upright and the long bolt is proving difficult. Car has seen some weather in its life and the bolt is pretty
bound up. Used various penetrating oil so far with out much luck putting a disposable nut on bolt and giving it a whack has not done anything.
Letting it soak overnight. Did others have to use heat or ??
Thanks for any replies.
