Making progress. I was on vacation last week and actually wrote stuff to catch up on my build log. Just need to plug in photos and I can update that thing. I'm sure you are all breathlessly waiting... In the meantime, a few aluminum oriented questions. Nothing huge, but I couldn't find any definitive answers in my google search or in the manual, so where do I go? Here!
1. Footbox. Outside wall bottom (both sides). Should they be inside or outside the floor? (inside = between floor and frame.) Here's the thing: I documented where everything was when I dismantled it, except for these few items.
2. Footboxes: floors get riveted through the tube part of the frame, don't they? It would make sense, but thought I'd see what the collective wisdom is.
3. Does it matter if the front tunnel "A" frame piece is inside or outside of the footbox inside walls? (inside means you see the seam from the engine bay, which is what I do not want.)
4. Logically, it makes sense to me to hold off on riveting panels now. At what point would you actually take the drastic step of actually riveting these things in place? Once the "plumbing" is complete, or would you wait until some other step? Why do I ask? I'm running out of clecos!
I look forward to your comments!
