Results 1 to 2 of 2
Thread: Fe builds
    May 2013
    Slidell la
    Fe builds
    This goes out to the big block guys, did y'all encounter the flange on the headers hitting the body on the drivers side? If so, how did you fix it? The body is stretched out on the frame pretty much as far as I can go because of the door alignment issue. Any advise is appreciated.
    Mk4 # 8834 delivered 03/20/16 2015 IRS wildwood brake upgrade, 18"x9" front 18"X11" rear halibrand wheels, 390 FE, tko600
    FRont splash panels installed yet? Even with the lower body pulled in at the front of the door the splash panels can flex it outward right behind the wheelwell which may help.
