Page 2 of 2 FirstFirst 12
Results 41 to 48 of 48
Thread: DanielsDM 818R
    Quote Originally Posted by DanielsDM View Post
    Time for an update.
    Been working on the dry sump system. Pump is a Johnson's HTP 4 stage (3 scavage + 1 pressure). Just barely fits in the AC compressor locations.
    My design extends the hose connection to the front of the motor so the hoses stay further away from the exhaust.
    The filter will be moved to remote location the factory heat exchanger removed.
    Next is temporarily mount the body to figure out where to put the DS tank and oil/water heat exchanger, and well... everything else.
    Hey Dan,
    With the engine movement, you are really close to the frame with the DS pulley shaft.
    I did a video with stock motor and trans mounts and got excessive engine movement.
    You will need stronger mounts and maybe a dogbone.
    Reno, NV
    Hey Dan,
    https://www.youtube.com/edit?o=U&video_id=9cPHXm8AXkc
    Thanks for the heads up Bob. I plan on using very stiff engine mounts, maybe solid. Even so there will be some flex in the chassis and mounts, the 1/4" gap may go away under hard braking. Something to pay attention to. BTW the video link isn't working for me.
    Quote Originally Posted by biknman View Post
    Excellently! You sir set the standards for all others to follow!
    Thanks.
    818R Build date 10/31/15
    Don't do solid mounts! you will loosen every bolt in the car. Torque Solution and Perrin mounts both have 75A durometer bushings, which is the stiffest I could find without being solid, and our engine doesn't move.
    Bowling Green, KY
    Cusco engine and trans mounts did the trick for me.
    USA
    I have had solid aluminum motor and transmission mounts for over 3,000 miles now. The stock mounts were ridiculous. The drivetrain needs the dogbone if you run stock mounts. I've had no issues so far with things rattling loose. Lock nuts and medium threadlocker must be doing their job. It's really not that noticeable. I mean, the car is not quiet to begin with, so all you get is a bit more drivetrain whine.
    https://www.aluminati.us/products/al...d-motor-mounts
    https://www.aluminati.us/collections...id-trans-mount
    Reno, NV
    Worked on addressing the open tube frame issue where the main hoop sets on an open ended square tube.
    I milled some 1.5" long plugs that match the inside dimensions of the tube
    After some grinding and file work on the tube and plugs they fit nicely. Next step weld them in place.
    IMHO, this is a better solution than simply welding a plate to the end.
    Bowling Green, KY
    Nice job on the pan.
    Reno, NV
    Thanks.
