What's the trick to getting the junction of the A pillar/hood and fender to come together?
And does it look like the A pillar was cut to high on mine?IMG_6441.JPGIMG_6444.JPG
Can you push down the front -window frame & A pillars of your hard top using the adjustments in the slotted portion of the bolt holes?
I had about 1/2" adjustability front/back & up/down when I installed mine and used that to fine tune the alignment of the A pillars to the fenders.
It's down all the way in the pic, the diver side cut is 1/2 lower than the passenger side
I trimmed my tabs off to fit the new front end, you still have yours on I see.
I also trimmed the extra material off the fenders. I think if you keep the fender mounts loose and the windshield mount bolts loose (loose, but tight enough that things stay where you put them), you'll be able to find a place where it looks good. Of course, the side sails should be in position securely in proper location as they locate the bottom of the fenders. I also checked to see how on-center my wheel hubs were in the front and rear openings. I have read that others clamp the nose/grill in place also to set that positioning.
One other thing I noticed on my side sails....they have a bit of a set to the shape which requires me to push down fairly hard on the door sill/rocker area. The three pictures show a bubble level on my roll bar to ensure car is level for reference, and then the top face of the door sills on the side sails. Note how un-level the surface is until I put my body weight on it (220lbs). Now, this may not be necessary, but it does impact the final location of the fender (they are bolted together), and also, it would tend to force water in towards car due to the slope. Also, my doors are tight enough that I think the extra clearance is worth getting.
I think if I hold the sails down while drilling to the frame along the sides of the car, I will get some of this leveled out, though I doubt I will get all of it, some will flex back.
Sorry so long winded!
-Ben
thanks for the input, I did trim the extra material off the fenders and things are fitting better.......im worried that the A pillar is cut to high tho. guess ill have to wait and see now that all the "must Have" alignment points are set up. Ill put the roof back on soon and see
Do you have the pieces that you cut off for reference?
There is a product called 'kitty hair' and others that are stranded fiberglass in resin that you mix hardener into, like bondo. It can be used to rebuild bulk areas and is easily filed and sanded to shape. Down side is you'd have to apply the gelcoat layer, or paint the area. Point is you can fix if cut too much, though I am fairly certain you will get it all to line up acceptably!
Good luck.
