Results 1 to 4 of 4
Thread: GTM completion kit parts from donor 01 c5 corvette
    Hi all,
    I had planned on building a GTM, but bought a 427 corvette convertible this summer instead. As such, I'm selling the parts i collected from the donor car. Asking 4500 on ebay, but will sell direct for 3999. Has almost everything except the driveline, wheels etc. Will update later with complete list and parts. I'm in Greenville sc.
    Thanks, Joshua Meeks
    I am selling a donor completion kit so that you don't have to start off your GTM supercar project by buying and dismantling a Corvette (which will save you 50-100 hours). I have already done all of this work for you, and selling the parts needed for you to get started. It is a near complete kit of what you need, gathered directly off of Factory Five's own donor list. I have included the list below and made annotations as necessary. I have pulled a few items out of order and put those at the bottom under parts not included (in red print) so that you know exactly what you are getting. I have everything very organized. Many parts are individually bagged and labelled, and all hardware is included and labelled unless is is still attached to the relevant part. All parts are used and painted parts may have cosmetic scuffs/scratches and will likely need repainted.
    GTM DONOR PARTS LIST (1997-2004 C-5 CORVETTE)
    SUSPENSION
    1 pair LH/RH Front lower control arms (rubber bushings installed and ball-joints pressed in)
    1 pair LH/RH Front upper control arms (rubber bushings installed)
    1 pair LH/RH Knuckles (upper ball-joints pressed in)
    2 each Front bearing/hub assembly
    1 pair LH/RH Hub backing plates for wheel speed sensor wiring attachment
    2 each Locknuts for lower ball joints (M14 x 2mm)
    2 each Locknuts for upper ball-joints (M12 x 1.75mm)
    6 each Torx bolts (T55) for bearing/hub assembly to knuckles (M12 x 1.75mm x 55mm)
    8 each Bolts for upper control arm to chassis (M10 x 1.5mm x 35mm)
    8 each Washers for upper control arm to chassis (10mm)
    4 each Cam bolts for lower control arms to chassis (M14 x 2mm x 110mm)
    4 each Locknut for lower control arm bolts (M14 x 2mm)
    4 each Cam washers for lower control arm bolts
    4 each Bolts for lower shock mount (M8 x 1.25mm x 45mm)
    4 each Locknuts for lower shock mount (M8 x 1.25mm)
    1 pair LH/RH Front rotors
    1 pair LH/RH Front calipers with sliders and hardware to attach sliders to calipers
    4 each Bolts for front calipers to knuckles (M14 x 2mm x 47mm)
    4 each Washers for calipers to knuckles (5/8” ID, 1 1/8” OD)
    2 each Flexible brake lines with mounting brackets (front, slightly shorter than the rears)
    2 each Banjo bolts with 4 crush washers for brake line attachment to calipers (M10 x 1.0mm)
    2 pair Front brake pads
    10 each Lug-nuts for front suspension (M12 x 1.5mm)
    1 pair LH/RH Rear lower control arms (rubber bushings installed and ball-joints pressed in)
    1 pair LH/RH Rear upper control arms (rubber bushings installed)
    2 each Rear bearing/hub assembly
    2 each Cam bolts for lower control arms to chassis, forward most mount (M14 x 2mm x 110mm)
    2 each Locknut for lower control arm bolts, forward most mount (M14 x 2mm)
    2 each Cam washers for lower control arm bolts, forward most mount
    1 pair LH/RH Rear rotors
    1 pair Rear calipers with sliders and hardware to attach sliders to calipers
    4 each Bolts for rear calipers to knuckles (M14 x 2mm x 47mm)
    4 each Washers for rear calipers to knuckles (5/8” ID, 1 1/8” OD)
    2 each Flexible brake lines with mounting brackets (rear, slightly longer than the fronts)
    2 pair Rear brake pads
    10 each Lug-nuts for rear suspension (M12 x 1.5mm)
    2 each Outer CV-joints
    2 each Locknuts for outer CV-joints (M27 x 2mm)
    2 each Rear toe link
    2 each Locknuts for rear toe link to chassis (M16 x 2mm)
    2 each Rear outer tie rods with jam nuts (M14 x 1.5mm)
    2 each Locknuts for tie rod ball-joints (M12 x 1.75)
    E-BRAKE
    1 pair LH/RH E-brake backing plates (includes brake shoes and cylinders)
    1 pair LH/RH e-brake cable to knuckle brackets
    4 each Bolts for e-brake cable to knuckle brackets (M10 x 1.5mm x 70mm)
    2 each E-brake cables
    1 each E-brake handle (includes attached front cable with equalizer bar, black hand grip and boot)
    1 each E-brake cable connection bracket (connects front cable to both rear cables)
    FUEL
    1 each LH Fuel tank with pumps and sending units
    1 each RH Fuel tank with pumps and sending units
    1 each Fuel tank connector tube (only necessary if tanks came from 2003-2004 donor) - not necessary, but still included
    1 each Fuel filter
    1 set Hard lines connecting filter to tank (3 total)
    COOLING
    1 each Fan shroud
    2 each Fans with attached motors and screws to attach to shroud
    1 each Radiator
    1 each LH/RH Radiator lower rubber isolators
    1 each Coolant overflow tank
    1 each Cap for coolant overflow tank
    ELECTRICAL
    1 each Computer 2 piece mounting bracket
    1 each TAC module (for fly by wire throttle) - 1 mounting tab repaired
    1 each Throttle pedal (fly by wire)
    1 each Fly by wire harness (connects throttle pedal to TAC module) - This is a complete harness, not just the connector plugs
    2 each Short 4 wire oxygen sensors
    2 each Long 4 wire oxygen sensors
    1 each Vehicle speed sensor (VSS) with mounting bracket
    1 each Brown/(GRAY) plug that connects to the under-hood fuse box with about 6-12 inches of all wires extending out (Mine is actually Gray, from an 01)
    of it (for connection to the fuel pump, and ignition switch)
    1 each White plug that connects to the under-hood fuse box with about 6-12 inches of all wires extending out of it (for connection to cooling fans and air pump, fuel level sender, and vehicle speed sensor VSS)
    1 each OBD2 Engine scan plug with about 6-12 inches of all wires extending out of it
    1 each Wiring plugs for fans, fuel tanks, brake light switch, wiper motor to steering column
    1 each Under-hood fuse box
    1 each Brake light switch with plastic holder
    1 each Ignition switch
    1 each Ignition cylinder, lock cylinder(s) and 2 key set (These are from the 99 Donor such that all keys match door cylinders)
    MISCELANEOUS
    1 pair LH/RH Exterior door handles with gaskets (These are from the 99 Donor such that all keys match door cylinders)
    1 pair LH/RH Exterior rear view mirrors w/mounting nuts
    2 each License plate lights with bulbs, mounting screws (leave about 12 inches wire from each bulb socket)
    1 each Horns with mounting bracket (high note and low note)
    1 pair LH/RH hood latches
    1 each Hood release handle and 2 attached cables
    2 each Hood strikers
    1 pair LH/RH hood hinges
    1 each Wiper motor with rotating assembly and 3 mounting screws
    1 pair LH/RH Power window mechanisms (These are from the 99 Donor)
    1 pair LH/RH Seat belts w/upper bolt plastic covers (These are from the 99 Donor for correct hardtop seatbelts)
    2 each Seat belt receptacles
    1 each Steering column (w/stalks, 2 piece cover, steering wheel nut M14 x 1.5mm) - (This is from the 99 Donor to get non-telescoping style)
    PARTS NOT INCLUDED
    Engine (LS1) Be sure to have 1997-2004 exhaust manifolds, alternator, motor mounts w/hardware,
    throttle body, mass air sensor, A/C compressor (if running A/C), drive belt idler pulley, belt tensioner w/pulley, emissions pump(if running emissions), etc .
    1 each OBD2 PCM computer
    1 each Engine Harness
    1 each Battery
    2 each Front wheels
    2 each Rear wheels
    2 each Front tires
    2 each Rear tires
    1 set Transaxle (Porsche G50) with flexible mount, inner CV-joints, starter, clutch, pressure plate, throwout bearing, shift fork, and shift fork shaft
    Pm sent
    Sent an email. I don't check this forum as often as I used to, so anyone with interest can email me for a quicker response at Mercer2014ATgmailDOTcom. I'm happy to provide my phone number to anyone with interest and can physically show to anyone locally or willing to make the trip in person.
    Joshua Meeks
