Thread: 33 exhaust
    May 2016
    North of sacramento Ca.
    33 exhaust
    Need help on 33 coyote exhaust. Do Not seem to get it to fit. And looks like the DS 02 sensor will hit steering shaft. Is there any other parts other than header down pipes that could be different, headers fit, and i did move motor some but not that much. If i need to make it different i can weld stainless.pics for hot rod net0091.JPGpics for hot rod net0093.JPGpics for hot rod net0097.JPGpics for hot rod net0094.JPGpics for hot rod net0099.JPG
    May 2016
    It would help if anyone could post pics of ther rear exhaust setup.
    Simi Valley, CA
    Did you get a set of exhaust pipes with the flanges reversed? This was an error by the manufacturer that FFR announced back in March - right about when my kit was delivered. They sent me new pipes with the correct flanges a few weeks later - without me asking, IIRC. This post explains the problem and shows misalignments similar to what you're showing: http://www.factoryfive.com/whats-new...t-rod-exhaust/ Hope that helps.
    Keith
    May 2016
    Keith
    Thank you, that is the problem, and it will not fit any way you try! I looked at info but did not see this.
    Will call FFR.
