Perfect for you builders looking to go with an automatic overdrive as the stock kit radiator does not have provisions for transmission cooling!
This is a brand new, never installed Flex-a-Lite Translife fluid cooler.
Product link with full specs: https://www.summitracing.com/int/par...illocation=int
With this I have four -6 AN PTFE steel fittings to plumb the cooler (two straight, two 45*) and a Derale thermostatic switch.
All in this would retail for $260. All you have to do is purchase -6 PTFE hose in the proper length for your build!
$200 shipped to the lower 48!
Thanks!
Mark
