Ok so if you have followed my 20 threads with different questions you know that my plan has changed a bit. For the sake of simplicity here is my plan..
Complete kit
Stainless sidepipes
Chrome roll bar
Roll bar trim kit
Wind wings
Visors
Reclaimed sn95 rear end with axles from richern obren
351 long block from tristar with eldebrock performer intake and Holley 750dp
Tko from forte with bellhousing and miscellaneous parts to meet up with engine
Hammertone on panels. Undercoat on the backsides
Herculiner on underside of body
17x9 halibrands in front
17x10s in the rear
My question is in regards to the brakes. I want to grab some 13" rotors for the frot and cobra calipers. What will I need in the way of brackets/ hoses. I also want to upgrade the rear with cobra calipers and bigger rotors. Not sure if this will work with the fox width axles and sn95 style cobra calipers and rotors. I know Richard obren can supply most of what I need but I have a lead on cobra calipers in really good shape and I like the idea of them peaking through.
Thanks for any help as always!
